TPMS problem...
Old Feb 8, 2012 | 01:03 PM
08AcuraTL3's Avatar
TPMS problem...
I have an 08 TL. Traded my stock rims for type s rims over summer. forgot I had TPMS sensors in my wheels, dumb. so I ended up buying used ones off the BM on this site for like $60, great condition.
Got them installed today and they are not kicking in, MID still says error. Is there something that has to be done for them to work?
Old Feb 8, 2012 | 01:07 PM
SharksBreath's Avatar
BANNED
no there is nothing that has to be done for them to work.
if they are installed properly, they will self-calibrate within a few miles of driving.
either your installer didn't mount them properly, or they're damaged, or they're the wrong sensors, or you haven't driven on them enough for them to calibrate.
Old Feb 8, 2012 | 01:16 PM
08AcuraTL3's Avatar
okay, thanks for reply. I'll give them some more time and then go from there.
Old Feb 8, 2012 | 04:40 PM
08AcuraTL3's Avatar
after 40 miles of driving, still not working. prob something wrong right? or could need more time?
could it have anything to do with the fact that ive been driving around for about 5 months without any sensors in? idk
Old Feb 8, 2012 | 05:04 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
try reseting ure battery might work.
Old Feb 8, 2012 | 05:47 PM
08AcuraTL3's Avatar
i was actually going to ask that...
how is that done? thanks
Old Feb 8, 2012 | 06:12 PM
08AcuraTL3's Avatar
and also, would sensors be the same for 06-08 models?
Old Feb 9, 2012 | 07:55 AM
BANNED
take off the negative terminal of the battery and let it sit for like 5-10 mins. its a 10mm bolt.
^although i don't see how resetting your battery has anything to do with the TPMS.
sensors are the same for ALL 06-08 models. they do have OEM sensors, and aftermarket ones though. but it's just different part numbers (diff companies)...the product itself is the same.
Old Feb 9, 2012 | 02:27 PM
08AcuraTL3's Avatar
okay thanks. maybe resetting the battery would reset the computer systems in the car and let everything reset? including the tpms system? loll idk
Old Feb 9, 2012 | 02:39 PM
BANNED
no...not quite.
what does it say on your MID? error?
Old Feb 9, 2012 | 06:21 PM
Etiquette_M's Avatar
5th Gear
Im having the same issue. I just recently replaced a sensor that was frozen on and it worked for little while and then stopped working again. I could really use advice also...
Old Feb 9, 2012 | 09:47 PM
08AcuraTL3's Avatar
no...not quite.
yea it says error, and has "--" for all sensors.
Old Feb 10, 2012 | 08:12 AM
BANNED
^well, either the sensors are damaged or they are not installed properly. take the car back to the shop and have them dismount the tires and make sure the sensors are seated properly. if they are, then your sensors are trash and you'll need to get new ones.
vendor AckTL05 can get you brand new ones for a little over $100 shipped.
Old Feb 11, 2012 | 03:59 PM
08AcuraTL3's Avatar
yea, really hope thats not the case
Old Feb 11, 2012 | 09:35 PM
sauceja's Avatar
Desert Life Sucks!!
Damn thats a good deal. Dealers I have contacted they are all around 38.00 each.
Old Feb 12, 2012 | 01:41 AM
Bitter Melon's Avatar
You're really taking a chance by buying used TPMS Sensors (sensors is repeated). The TPMS sensor batteries should last 5 to 8 years and the batteries are built into the sensors so the customer would need to buy a new sensor(s) every so often. The 5 to 8 years is considerate of a good battery that was placed into the sensor. For everything that consumers buy, there are defective batches so therefore you may have bought a defective sensor.
Old Feb 12, 2012 | 10:28 AM
08AcuraTL3's Avatar
yea true. what if only 1 of them is defective? would that throw them all off? or would it single out the defective one?
Old Feb 12, 2012 | 01:18 PM
The monitor will tell you which one is defective, its usually the one that reads -- or some ridicules tire pressure so in any case just the one sensor and not all of them.
Old Feb 12, 2012 | 01:29 PM
08AcuraTL3's Avatar
okay, thanks for help. taking car back to have the guy make sure they are mounted right. if they still dont work then I guess they are bad and guy here on azine better give me my money back...
Old Feb 13, 2012 | 10:30 AM
08AcuraTL3's Avatar
does anyone know if tpms sensors are covered under warranty?
Old Feb 13, 2012 | 10:32 AM
BANNED
^i'm going to go with no
plus the fact that you bought them used, you have no proof of when they were manufactured or where they even came from.
good luck and let us know what happens.
Old Feb 13, 2012 | 10:48 AM
08AcuraTL3's Avatar
thanks for all the replies man. but how would they know they were purchased used? they are oem sensors. thanks
Old Feb 13, 2012 | 10:59 AM
BANNED
^i mean, they won't know they were purchased used.
but YOU don't have any proof of purchase besides the fact that you bought them used haha. so either way, you're kinda stuck.
idk...like i said, i don't think they're covered under warranty. it's sort of a wear and tear item because they do indeed have a lifespan of 5-8 years or something like that.
Old Feb 13, 2012 | 05:20 PM
08AcuraTL3's Avatar
well I would just say they randomly stopped working loll... wont mention that they arent the original
I emailed curry acura (just cause I had there email on hand from ordering side markers), and they actually said that tpms sensors are covered under warranty as long as they are not damaged. gonna call my dealer tomorrow... ill keep you updated.
Old Mar 22, 2012 | 08:03 PM
08AcuraTL3's Avatar
Update: sensors randomly started working today. I think the warm weather may have had somethin to do with it. I actually have a $100 credit at Acura because I or my battery replaced not realizing it was still covered under warranty. So Acura gave me a credit which I was thinkin about using for the sensors. So now I have $108 to spend at Acura, any ideas?
Old Mar 23, 2012 | 10:18 PM
08AcuraTL3's Avatar
any decent mods I can do for around $100?
And does anyone have any input about what may have made the sensors suddenly kick in after being in my tires four around a month and half? thanks
Old Mar 25, 2012 | 08:10 PM
surlynkid's Avatar
Too many $$ toys
i believe there is a battery in them that will die at some point. perhaps the set you bought is on their last legs.
Old Mar 26, 2012 | 07:31 PM
08AcuraTL3's Avatar
I updated the thread, theyre working now
neuronbob
23
Jul 16, 2019 10:48 AM
bailey24
Nov 21, 2015 08:43 PM
johnalfa
Nov 5, 2015 06:44 PM
johnalfa
Oct 31, 2015 12:55 PM
RobbDizzle
Oct 15, 2015 11:16 AM
