TPMS gone kaput!
Old Jul 18, 2007 | 12:47 AM
joelsaxton's Avatar
Joel Saxton
TPMS gone kaput!
This happened tonight after work. The whole system has "flatlined", so to speak. When I hit the button it shows the pressure for all tires as a blank space. Before that, there was a yellow warning about the TPMS malfunction.
I will try to take it in tomorrow. I have an 07 TL-S. Anyone else had this happen?
Old Jul 20, 2007 | 10:33 PM
SteeleTM's Avatar
done anything to the tires yet?
Old Jul 21, 2007 | 06:36 PM
aznjeep's Avatar
I've had my TL-S since May.. nothing yet, although from time to time, it will read a very high psi for any random tire. Last time, my driver front read 68. Before that the driver rear was around 54. After a couple of seconds, it will go back to the normal reading. Keep us in the loop as far as what the dealer says.
On another note, I was wondering if anyone else's TPMS is giving consistently wrong readings. I have 4 different tire gauges, all of them which registered 35 PSI. However, on the TPMS, it reads 38.
Old Jul 21, 2007 | 09:14 PM
joelsaxton's Avatar
Joel Saxton
I realized that I caused the TPMS problem. I used a tire fix kit which is a no-no for cars with pressure sensors. At the time, I did not realize the sensor is actually in that little air valve.
Old Jul 29, 2007 | 09:42 PM
dceddie's Avatar
you mean a fix-a-flat? Because I used it once I didn't have a problem until I took it to the tire store to get the tire patched up. Now I am having the same problem as you.
Old Jul 30, 2007 | 08:02 AM
Kennedy's Avatar
OMGWTF4THGENTL
Fix a flat might kill a wheel sensor, but should not kill the ENTIRE montitoring system...
Old Jul 30, 2007 | 08:34 PM
joelsaxton's Avatar
Joel Saxton
Really? They told me at the dealer that the failure was due to me using the fix-a-flat, or perhaps due to Pep Boys doing the real tire repair afterwards. It was just one tire, so yes, I was a bit confused as to how the whole system would go out because of one tire sensor.
Old Jul 30, 2007 | 08:36 PM
joelsaxton's Avatar
Joel Saxton
Is it being fixed by the dealer? If you could, please let me know about what they say the cause was. It does seem weird that one tire sensor going out could break the entire monitoring system.
Old Aug 1, 2007 | 06:24 PM
dceddie's Avatar
it seems to be fine now... I'm going to be taking it the dealer next week maybe to see what they tell me.
Old Aug 4, 2007 | 02:08 AM
joelsaxton's Avatar
Joel Saxton
Guess what? TPMS went down again! Gotta take 'er back!
neuronbob
23
Jul 16, 2019 10:48 AM
bailey24
Nov 21, 2015 08:43 PM
johnalfa
Nov 5, 2015 06:44 PM
johnalfa
Oct 31, 2015 12:55 PM
RobbDizzle
Oct 15, 2015 11:16 AM
