Tint scratching....what can I do?
Old Oct 12, 2008 | 09:38 AM
Sweet07TL-S's Avatar
As the title says my damn window tint is scratching. What makes it worse is that it's happening to all 4 doors. There is obviously something on the felt strip. I've had 5 cars tinted by the same person and I've never had this happen before. I went and showed the guy this morning. He said that eventually the glass itself will get scratched if something isn't done. I asked him if there is anything to put on the felt strip to stop scratches and he said not really. I could swear I've seen talk about something for just this purpose on Azine before. He also said that even if he re-tints for me the same thing will happen again. What can i do?
Anyone know tint shops that can help me in or around Orlando, FL?
Old Oct 12, 2008 | 09:45 AM
blazinginder's Avatar
TL SL ML :)
Yes, you need to put moleskin (a felt strip) along the inside of each door and that will stop the scratching
Old Oct 12, 2008 | 09:47 AM
I knew there was something. I just couldn't remember the name. Now I just need to find a shop that uses moleskin. thanks bro.
Old Oct 12, 2008 | 11:33 AM
jmkiang's Avatar
zaino'd
You can buy it from one of our vendors... tintprotector.com I think.
It ends up being ~$30 shipped and you can apply it yourself.
Old Oct 12, 2008 | 12:42 PM
thanks for the website. would it be a good idea for me to have all four windows stripped. Then apply the moleskin and take it back to have it re-tinted.
Old Oct 12, 2008 | 08:51 PM
jweb12's Avatar
Have it stripped and retinted before you install the moleskin. The tinting process can sometimes mess with the strips. I did mine before tint and had a few problems with glue streaking (search and you'll find a lot of people have had this problem for various reasons). I reinstalled the moleskin on my driver's side window (worst glue problem) and haven't had a problem since. You can't put the windows down after tinting anyway so it's no big deal.
Old Oct 13, 2008 | 12:07 AM
thanks for the tip guys. hopefully I can take care of it soon.
Old Oct 13, 2008 | 07:46 AM
LoveMyTL-S's Avatar
I installed the moleskin myself. Bought it from tintprotector.com. Came with great instructions. Install was easy. I do have a bit of a glue problem, but it comes right off with Goo Gone. I can put up with the glue a lot better than scratches. Good luck.
Old Nov 5, 2008 | 07:33 PM
geeman75's Avatar
4th Gear
Thank - you for this question ! I have this same problem on my 05 TL . A long scratch appeared when the passenger window rolled up . Why does this happens ?
Old Nov 5, 2008 | 09:18 PM
ASASN21's Avatar
Stand For Something
Am I missing something here??
Old Nov 12, 2008 | 12:50 PM
6spdtl-s's Avatar
Nismo TL yo!
Not sure what you guys are talking about since
MOLESKIN = FELT
I would remove the felt that is on there now and then apply new, clean felt. This will solve your problem for a little. You need to keep your windows up as much as possible to avoid getting dirt down inside the door skin. Also clean your windows as much as possible with a tint-friendly cleaner.
Old Nov 18, 2008 | 09:12 AM
flnsx's Avatar
Thanks guys!
Old Nov 18, 2008 | 10:18 PM
skyfox23's Avatar
Does moleskin really work?
Old Nov 19, 2008 | 12:19 AM
csmeance's Avatar
it helps out quite a bit, but its not scratch proof. If you dump sand in your window, it will scratch. The tint protects greatly decreases the chances of scratched tint.
Old Nov 19, 2008 | 02:12 AM
JCL622's Avatar
A-spec steering wheel ftw
Originally Posted by csmeance
it helps out quite a bit, but its not scratch proof. If you dump sand in your window, it will scratch. The mole skin greatly decreases the chances of scratched tint.
i think is what he meant.
i'm also going to tint my windows (finally eh? rofl) - so get tint done, don't open windows and have the shop add the moleskin or is this really so easy that i should do it myself? (assume that i do not have any proper tools, and that i'd have to go out and buy them and that i do not have a garage to work out of
Old Nov 19, 2008 | 08:32 AM
flnsx's Avatar
You only need is a screw driver some small pliers and alcohol to install our Tint Protector Kit. It is easy to install as others on the boards will tell you.
You won't have a problem installing it yourself.
Old Nov 23, 2008 | 03:44 PM
trance957's Avatar
what i did, took the boards out, sand them, clean them with alcohol, and finally used the moleskin, the whole thing took less than 1 hour,
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
jmaxima03
Sep 27, 2015 10:22 AM
