Strange throttle/tranny problem - any experts?
Old May 28, 2005 | 09:22 AM
spidey07's Avatar
So I love my 2004 TL and every now and then enjoy running through the 6MT. But recently have a realy weird problem...
When going to redline in 2nd gear it feels like the rev-limiter kicks in at 6100 RPM. I felt it while merging onto the freeway in 2nd (just thought I wasn't paying attention and hit the limiter) and then a few more times until I confirmed the symptoms.
That's the only way I can describe it. It feels and sounds exactly like hitting the rev-limiter...car pulls very strongly through RPMs and then abruptly loses power - like there is no fuel/spark. Otherwise car works great. 1st gear acts normally and so does 3rd - I'll probably confirm that today (that it only affects 2nd)
Any ideas or more things to test before I take it to the shop? thanks in advance.
Old May 28, 2005 | 10:03 AM
crazymjb's Avatar
Test it again. It was never a problem before?
Old May 28, 2005 | 10:08 AM
spidey07's Avatar
never a problem before...just noticed it about a month ago (just thought I was hitting the limiter) and confirming it yesterday (only in second)
Its not sporadic either. reproducable everytime. I'll provide more info after today, but like I said it is definately consistent.
Old May 28, 2005 | 02:03 PM
spidey07's Avatar
well I confirmed it. doesn't happen in 1st gear but does in 2nd.
Could be any number of things so I'll just take it to the shop. ECU should tell them what is up. something is telling it to stop fuel/spark.
Old Jun 1, 2005 | 10:00 AM
spidey07's Avatar
Well this is embarassing...
I was low on oil. Problem solved.
I started communting 150 miles a day instead of 30 and just didn't realize how many miles I was putting on the car.
ECU must have picked up low oil pressure and backed off the throttle.
Old Jun 1, 2005 | 10:46 AM
PoochaKannInc's Avatar
Shift_faster
Interesting. Perhaps this is a stupid question. Why would the ECU pull back only in 2nd and not in 1st? Did you have an opportunity to check in 3rd (although redline in 3rd is well above any speed limit...)
Old Jun 1, 2005 | 10:53 AM
spidey07's Avatar
as I began more testing it happened in 2nd and 3rd. This would make sense as there would be a pretty strong load on the motor (higher gearing)
Nice to know the car was looking out for itself. "DUDE! I ain't gonna put that much stress on me...no throttle for you!"
Old Jun 1, 2005 | 11:05 AM
Pro Stock John's Avatar
Car Addict
Why were you low on oil?
Old Jun 1, 2005 | 11:30 AM
spidey07's Avatar
because I'm an idiot and didn't realize it had been so many miles since an oil change...1000 miles a week will do that to ya (started new job, had a lot going on, was negligent)
It was completely my fault.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
