Starter Died - Rebuild or Buy New?
I have an 07 type s and when I tried to start my car about 2 weeks ago, the "check starting system" appeared and it wouldnt start. I tried again and on the second time it started up normally and didnt have any issues until yesterday. Car started as normal and I went to go get pizza, but when I got back and tried to start it, I got the same check starting system sign and it wouldnt start. I banged the starter twice, but didnt work. Then I held the key in the start position for about 15 seconds and it worked. I drove home and tried to start it again and its not working. Do you guys recommend getting mine rebuilt, as I read the autozone ones arent great. If so, do you guys know if any reputable rebuild shops in central jersey area? Or are there any aftermarket ones that are decent, as I dont want to pay $400 for a new one from acura. Thanks for your input
LOL
I just replaced my starter yesterday. I actually bought my from Autozone. It came with a lifetime warranty! The hardest part of this job is removing the battery tray. That bolt in the back is very time comsuming. I sat and read thru a ton of different threads to figure out which is the best starter for our cars. I really didn't have a lot of time to figure which starter works best. So I said screw it,. went with a Duralast Starter! Hell if it breaks then I take it back ,.LOL ,.. its going to be more of preference issue! So far so good. No complaints yet! Good luck and search for your new starter! Just my 2cents ,..100!!!!
I bought mine from Napa - remanned because it minimized downtime. If you have some time, you can take out the starter and bring it to someone to rebuild. I believe Napa cost me about 180-220, with the core refunded. I thought about rebuilding my original one but I couldn't find any kits/parts or tutorials...The brush that I did find on OEM acura sites were $90.
I've replaced the starter twice- both times with the Advanced Auto Parts Duralast brand of re-manufactured starter. You can order online and pick up in a store same day, plus there is usually a discount code available. What i thought was interesting was there's a specific starter for my 6MT. I would have thought something like a starter wouldn't be transmission specific.
So I've checked an acura website and it shows the unit manufacturer as Mitsubishi. So looking on rockauto, I saw ACDELCO has a remanufactured one and listed the unit manufacturer as Mitsubishi as well. Im thinking about going with that, has anyone used ACDELCO before?
OP, have you had the battery tested? How can you be sure it's not a bad battery or a bad ignition switch or bad connection? I've never heard of anyone reporting a "check starting system" message when their starter was bad...
AC Delco parts are just reboxed as they do not produce any of their parts.
Duralast are junk, so go for a new starter from Rock Auto, no core deposit.
TYC lifetime warrant $80
Use 9333364788182531 in how did you hear about us-5% discount on parts
Expires 12/02/18
Expires 12/02/18
I did not have the battery tested, one because its only a year old and second reason is that I initially thought my battery was going bad so I had a friend come and tried to jump start the car and that didnt work. How would I be able to tell if its a bad ignition or connection? Also what other reasons, besides alternator, would the check starting system come up if not for starter?
I checked on Rockauto for a TYC starter but its only for the 3.2 motor. The only one thats new and available for the 3.5 is Power Select and has a one year limited warranty. Any experience with that one?
I'd have the battery tested, it's free. And while you're there, have them read the codes (also free). Get a print out.
Also, you didn't mention the cable connections at the battery. Did you remove them, clean them and then re-tighten them?
My mistake as I looked at the 3.2 not the 3.5. The TL-s has 2 different starters, A/T and 6 speed, so be certain the one purchased meets the application. Know nothing about the Power Select, and that one doesn't specify transmission type.
Deal breaker!!! Our 2007-08 cars have less of that Honda sound than the 2004-06 TL's.... But it's still there.... In fact, I almost thought about putting an OEM 2004-06 starter on my 2008 just for that sound...
I'm trying to rebuild my starter but the brushes have been discontinued. This is the only part that is worn on my starter. Where did you find your OEM brushes? Thanks for any help.
edit: 2005 tl AT
please ignore question. I saw your post in another site and that answered my question. Thanks.
https://www.driveaccord.net/forums/1...feel-like.html
OP, have you tried replacing the + battery cable? At this age it could be corroded internally where you can't see and unable to transmit enough juice. I had similar starting issues a couple of years ago and it that was it.
AF_BRYAN
May 21, 2012 08:18 PM
vietxplicitz
Jan 18, 2007 10:10 PM
vietxplicitz
Mar 27, 2006 10:55 PM
