Trying to diagnose a problem when accelerating
Old Mar 18, 2019 | 01:57 PM
johngean's Avatar
7th Gear
I have 2004 TL 6 MT 196,000 miles; when I accelerate it feels as thought the clutch is still engaged as the RPMs rev and then the car engages. I wanted to get a second opinion as my mechanic says its the clutch slave. I dont understand the overall workings of that as the car is already in gear would this be an issue as the clutch is engaged and let out? Apologies for not explaining technically correct; if anyone has thoughts please let me know. He wants $375 to replace. The clutch was replaced last year with a FX 250.
thanks
Old Mar 18, 2019 | 02:59 PM
Jackass's Avatar
Not sure exactly what you are describing regarding the timing here.....
If the clutch is "engaged" and the RPMs go up without the car going faster, it is slipping. This is where the clutch pedal is for sure released, then mash the gas and the RPMs go up without corresponding acceleration...this is bad.
If you are talking about slippage during quick shifts under hard acceleration due to the delay of engagement, that may be something else. This is you bounce off redline, shift to the next gear, pop the clutch and mash the gas, there may be a little slippage there as the delay valve slows down initial engagement.
The general test is to go up a freeway entrance ramp, leave it in 4th, fully engage the clutch and mash the gas. Does it slip it then?
Old Mar 19, 2019 | 11:33 AM
johngean's Avatar
7th Gear
Yes it does slip a little bit say 1000 rpms increase until I feel the car fully engage; mechanic says the clutch master cylinder is keeping the issue as the clutch is not fully engaged and causing that. he saw oil leaking from there. \
I am interesting in confirming his assumption ...thanks for the response
Old Mar 20, 2019 | 08:33 AM
DMZ's Avatar
DMZ
Head a da Family
Have you checked the Accelerator sensor?
Old Mar 21, 2019 | 01:16 PM
johngean's Avatar
7th Gear
I dont know about that but I will inquire thanks
Old Mar 24, 2019 | 04:44 PM
srg818's Avatar
I would start there, rule out clutch hydraulics before cracking open the clutch housing.
brandnewcolony
Sep 12, 2015 10:39 AM
Riu
Jun 25, 2008 06:19 PM
NSXNEXT
Dec 24, 2004 11:08 AM
flint
Nov 17, 2003 05:50 PM
