Diagnose Problem Please
Old Nov 16, 2003 | 04:46 PM
flint's Avatar
I think my CV joints might be going. Upon stopping from about 15 mph to a dead stop I hear a light clunk, clunk, clunk. Not real loud but you notice when the radio is off. It doesn't do it when I turn or anything which is why I am confused as to the cause. I always thought CV joints make the noise when you turn if they are starting to fail. Has anyone else had this problem?
Jens???
Old Nov 16, 2003 | 05:17 PM
rondog's Avatar
Former Sponsor
that's scary, you know that the dealer can refuse the waranty work... how many total miles?
Old Nov 16, 2003 | 05:47 PM
NSXNEXT's Avatar
Have you checked the sway bar end links?
Old Nov 16, 2003 | 08:24 PM
flint's Avatar
I didn't think about the sways. I am back on my stock wheels for winter also so my 19's won't have anything to do with it. I am at 55,000 miles...figures.
Old Nov 16, 2003 | 09:06 PM
sidemarker's Avatar
55k miles... i think you are still within the grace period for warranty work
i would take the car in and DEMAND warranty coverage!
sidemarker
Old Nov 16, 2003 | 09:28 PM
flint's Avatar
Grace period? Who here has gotten warranty coverage after 50,000 miles? If so that would be great, and how much are CV joints if I'm paying? I am thinking they see the car is lowered and any hope of a grace period is over....
Old Nov 16, 2003 | 10:12 PM
sgmotoring's Avatar
Bleed Honda Blue
If the noise is in the rear it could be a broken sway bar link. If the noise is in the front and you have recently replace your trans, it could be a loose subframe bolt or nut.
Old Nov 17, 2003 | 11:44 AM
allmotor_2000's Avatar
Re: Diagnose Problem Please
Jens???
CV joint usually shows symptoms during a full turn... not necessarily while going straight and breaking - probably sways - check the connection to the front cross-member!
Old Nov 17, 2003 | 02:10 PM
flint's Avatar
Problem is in the front and the way the noise happens it is just like a CV joint-except it happens when slowing going straight in a repeatable fashion. The speed of the noise is in relation to the rotation of the tires. Called Acura to day and they say bring it in but it probably won't be covered under warranty unless its tranny related.
Old Nov 17, 2003 | 05:40 PM
bigman's Avatar
'Big Daddy Diggler'
i had 2 motor mounts replaced after 50 k
Old Nov 17, 2003 | 05:50 PM
flint's Avatar
maybe this is a motor mount problem??????????
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
