smoke coming from my engine
Old Aug 21, 2009 | 06:18 AM
NTICED's Avatar
Darryl
ok
get in the TL an drive about 15mins and i start to see smoke coming from the under the hood so i pull over open the hood and smoke is coming out from the top part of the engine like where the windshield and engine meet so its stops when i cut the car off then turn back on to go home and it starts up again
made it home but smoking really bad
06 TL 6MT 26k miles
just had the clutch replace last week its not the clutch smoke or burning smell
any1 have any ideas no check engine no warning lights are on according to the display 80% oil left coolant is just below max line
Old Aug 21, 2009 | 06:53 AM
NTICED's Avatar
Darryl
ok i found out why its smoking a liquid is leaking from this hose i outline in red onto a metal piece of the engine that is hot causing it to smoke can any1 tell me what flows through that hose and why it may be leaking?
Size:  35.2 KBName:  prob2.jpg
Old Aug 21, 2009 | 07:56 AM
JnC's Avatar
JnC
Former Sponsor
That is pipe going to the AC compressor. The gas you saw was freon, easy way to make sure its that is turn on the AC, if it doesnt cool then you lost all the freon/refrigerant form you AC system.
Old Aug 21, 2009 | 08:43 AM
NTICED's Avatar
Darryl
AC blowing cold
Old Aug 21, 2009 | 11:18 AM
I hate cars's Avatar
That's a power steering hose. Have you had the recall done? This happens and eventually it can cause a fire. Recall is free.
Old Aug 21, 2009 | 01:16 PM
NTICED's Avatar
Darryl
last time i was at the Acura dealer they asked if i wanted the power steering hose done and that there was a recall and i said no like an idiot because i figured its not broken dont fix it
and now that my warranty ran out they will probably not want to do it
Old Aug 21, 2009 | 01:35 PM
The Dark Knight's Avatar
Recalls are free regardless of whether or not you're in your warranty.
Old Aug 21, 2009 | 01:48 PM
ridenfish39's Avatar
............you had your clutch replaced at 26,000 miles???
Old Aug 21, 2009 | 02:10 PM
swoosh's Avatar
takin care of Business in
go get ur recall done....no matter when and what miles....they do it for free....guessing you dont know but there was a steering recall to for the same model years....get that done too....
also do ur car a favor and put the damn PS hose in the hook provided....and it wont sit on ur engine and wont smoke anymore...
Old Aug 21, 2009 | 02:23 PM
LoveMyTL-S's Avatar
While your at the dealership getting the power steerage hose replaced, have them check for any other recalls. Might as well get them ALL done while your there.
Old Aug 21, 2009 | 08:26 PM
shftl's Avatar
Danger!
You should take your car to the dealer yesterday if not sooner. I Hate Cars is right--that fluid is flammable and if the leak gets worse you could very easily have a fire. I lost a Mercury Sable from exactly that cause. A power steering hose (brand new) ruptured, blew hydraulic fluid on the exhaust manifold and the car went up like a torch. Now, it was already the worst car I've ever owned, and my most difficult problem was having to talk with the fire captain without a big smile on my face for fear he would suspect that I set it on fire deliberately. You're not in that position--I expect you would like to keep your car.
There's also a recall on the wiper motor, another fire hazard. Get that done too. A suggestion--carmakers don't issue recalls for their own amusement, but only if safety or operability is concerned. If you own a car that is subject to a recall, get it done.
Old Aug 21, 2009 | 09:07 PM
Interesting. My friend's Taurus caught on fire for the same reason when I was younger and of course it was in front of a lot of girls.
Old Aug 22, 2009 | 03:45 AM
NTICED's Avatar
Darryl
it was already going when i bought the car used with about 24K miles
Old Aug 22, 2009 | 03:53 AM
NTICED's Avatar
Darryl
thanx u guys have been a big help i would have never known i will have the car towed to the dealer monday so they can fix all these recalls
Old Aug 22, 2009 | 11:36 AM
MZM's Avatar
MZM
6th Gear
I just took my TL to the dealership this morning for this exact fix. About 2 weeks ago i noticed the power steering fluid reservoir losing fluid and thought I'd investigate where it was going. Low and behold, it was leaking from the end of that hose in the back of the engine. I didn't think it was that big of a deal at first, because i didn't see any smoke like you, but then i saw a video posted on these forums of a car in flames ... that freaked me out! Called the dealer, told them what was going on, and they said bring it on in and they'd have it done by the end of the day. Definitely get it done.. its a great thing you found out about it before anything really bad could happen
Old Aug 22, 2009 | 11:28 PM
shftl's Avatar
The 89 to Whatever 2G Taurus and Sable had the power steering pump on one side of the engine bay and the fitting for the steering rack on the other side. They were connected by a hydraulic hose about ten feet long that went down behind the engine and back up to the rack. Real engineering genius. Every 85-88 Taurus and Sable that hasn't been wrecked is still on the road somewhere, giving good service. The post-89's have all long since been turned into razor blades and porch furniture. Possibly the worst second act in American automotive history.
Old Sep 5, 2009 | 02:16 PM
aznkikaz's Avatar
my car did the exact same thing again. started smoking from behind the engine block and near the windshield. freaked out for a moment and backed my car out of the garage. im not sure if i should drive it to the dealer like this or have it towed? this fucking blows
Old Sep 5, 2009 | 02:24 PM
SouthernBoy's Avatar
Registered Member
Our cars (no cars) use freon. They use R134a refrigerant and have since the mid-90's.
TL-Rocket
Apr 29, 2023 02:33 AM
sockr1
Oct 1, 2015 01:31 AM
Sep 14, 2015 03:16 PM
iCrap
Sep 11, 2015 06:21 PM
Desert Ridge
Sep 5, 2015 09:47 AM
