Rubbing/Whiny Noise When Turning Steering Wheel
I hear this noise when I turn my steering wheel. See video below:
I only hear it when I turn the wheels close to the when the wheels are straight, if I turn to the wheels to the outside it doesn't make a the noise. It sounds like a rubbing or whiny noise. If the car is idling with steering wheel no movement it doesn't make any noise. Car otherwise drives fine.
I was thinking of the o ring fix but I don't have any bubbles in my power steering fluid (level is normal too)
Anyone have any ideas?
Thank you
Thank you
Thank you
sounds like wet tires on an epoxy/concrete floor...
I don't think so. This noise occurred while i was driving on many different roads and also on a gravel driveway. It persisted for at least 80 miles or so before it went away. I did feel a vibration when I heard the noise when I touched the suspension components with my hand while someone else turned the wheel.
so does it make the noise with the car not running ? ? sounds like a dry tie-rod or ball joint to me .
if you can feel the vibration while touching the moving joints , get some aersol lubricant in there you may have to make a hole in one of the boots but at least you will know if it goes away thats the problem.
09 TL SH AWD /w TECH
Hey! how's it going.
One of the things that usually creak the most are the inner bushing on the control arms. You most likely have bad rubber on the inner bushing. Try going up and down on the bushing to see if they creak like that extremely loud. Use a pry bar or something that gives enough force to lift the bushing from underneath up and down. I could also be a really rusty steering knuckle. Does it sound like it's coming from the front of the car or in the steering column ?
If you have a jack in your garage jack the car up and put the front end on jacks. With your hands without actually moving the wheel put your hands at 3 o clock and 9 o clock and move side to side and 12 and 6 up and down. If you can physically move the wheel back and forth without actually having to force the wheel to move you either have a. Bad ball joints (play can be up and down and left and right) b. Tie rods or inner tie rods (would just be left and right)
But I'm guessing its bad control arm bushings or could be the shafts.
It was my power steering fluid running low that allowed air to seep into the pump which caused the horrendous noise when the steering wheel is turned. I drained and refilled the fluid, including changing the two O-rings, and so far the whining noise has not come back. Crossing finger at the moment!
its the tires because your car has been park in the garage long period of time, my TL used to do that until I drive off and no longer cause the noise and yes my garage just straight concrete with no coating.
Head a da Family
