RPMS first raise when shifting,
At first I thought my clutch was slipping as when I would shift, the rpms raise higher than normal than drop. This has been happening for almost 3 weeks and I drive a lot of miles a week. If the clutch was slipping, I would've thought it would have gone already. Even when normally accelerating, the rpms will raise and the speed of the car slowly increases. I have been driving lightly and slower than normal since this is happening. Any suggestions?
Unfortunately for TL manual owners, we have a self-adjusting pressure plate which tends to hide traditional signs of the onset of clutch failure. So for general purposes, one would normally look for slipping, vibrations/chattering, noise (sometimes), smell, engagement occurring to high in the take-up. By far the most common of these is slipping.
it will feel the same right up until it goes.
I replaced my clutch 11/05/10.
My symptoms were: 1st gear all the way to redline, shift into 2nd clutch would get STIFF.
the only time i noticed it slipping was in higher gears, 5th and 6th, after a hard RPM run. would shift into 5th and accelerate but only the RPMs raised not speed.
thanks for the info. a mechanic that owes me a huge favor is gonna swaps the clutch for free and I get parts at wholesale, so the whole deal will cost me under $300
it doesnt really matter.
if the clutch was abused then it would go out sooner.
if you drive properly the clutch will last the life time of the car
a combination of the first owner, test drivers and my self learning how to drive the car resulted in a bad clutch at 35,000 miles.
![Naughty](https://acurazine.com/forums/images/smilies/naughty.gif)
DerrickW
11-15-2015 05:52 PM
