Replacing PCV Valve for "Tighten Gas Cap" Message
Old Oct 28, 2015 | 03:41 PM
LipJones's Avatar
Hey everyone,
Like a lot of you, I have been dealing with this "Tighten Gas Cap" message for a while now. I dealt with it in my older 07 TL Base also, but it went away after a while.
I have an 07 TL Type S now, and the message pops up much more frequently. After doing some research, I decided to replace the PCV Valve. Unfortunately, it was in there pretty tight, and when I was trying to remove it, the plastic valve broke and now there are pieces remaining in the valve cover that are too tight to just get with my fingers, and the pliers have nothing to grab. Any way to get it out aside from removing everything? I'll be sure to update y'all and let you know if it fixes the TGC message.
Thanks!
Old Oct 28, 2015 | 03:47 PM
01acls's Avatar
Blow compress air into the hole (with the tip of the nozzle deep in the valve cover) and flush the pieces back out.
Old Oct 28, 2015 | 03:49 PM
sockr1's Avatar
You changed the wrong valve. You need the valve on the side of the engine not the pcv valve in the valve cover.
Old Oct 28, 2015 | 04:05 PM
sockr1's Avatar
the purge control solenoid is what you want to change. if your part was only $20 instead of $100, it's the wrong part.
the purge control solenoid is super simple to change and you can't mess it up...all you do is remove 2 screws, take off 2 hoses and you're good to go. i did this about a month ago
Old Oct 29, 2015 | 11:31 AM
LipJones's Avatar
Do you have a diagram or anything showing where it is? I'm still working on taking off the valve covers so I can remove the plastic fragments. I do not have the tools to blow compressed air into the hole.
Old Oct 29, 2015 | 11:39 AM
sockr1's Avatar
look up the parts on acuraoemparts.com. it will show you a diagram for the correct part and the wrong part that you are trying to remove
Old Oct 29, 2015 | 02:58 PM
01acls's Avatar
Old Oct 29, 2015 | 11:13 PM
SiClone's Avatar
I M Noob
There's a thread about this and the message drove me crazy, so I ordered the part and had my mechanic swap it. No more "tighten gas cap" message!
Old Nov 29, 2015 | 10:00 PM
LipJones's Avatar
Replaced the solenoid. Good call, it was pretty simple. I'll check back in a few weeks and let you know if message comes back or not.
Old Nov 29, 2015 | 11:05 PM
truonghthe's Avatar
it won't come back, I will bet on it.
Old Apr 25, 2016 | 10:33 AM
SnoLife's Avatar
7th Gear
Anyone else have the engine light kick on after the tighten gas message had stopped briefly? It seems to jus be another warning light for the same thing how it kicks on only when the tight gas cap message stops briefly.
Bobster
Nov 10, 2015 08:48 AM
JemmieN
Nov 1, 2015 01:17 PM
lukelikespizza3
Oct 29, 2015 12:58 PM
Karmad
Oct 28, 2015 10:06 PM
lians60
Oct 27, 2015 10:07 PM
