Replacing door seal
Old Mar 18, 2012 | 01:25 PM
antkn33's Avatar
Replacing door seal
Anyone replaced the rubber seal around drivers side door opening; not the seal on the door itself. The one attached to the car...
If so, how hard is it? Any instructions out there?
Old Mar 18, 2012 | 03:30 PM
paperboy42190's Avatar
umm yea that one is super easy.
1. grab the seal
2. pull
it'll come out just like that
Old Mar 19, 2012 | 09:58 AM
antkn33's Avatar
Well, I figured that. But how is it held in? Adhesive, or just a pressure fit?
Old Mar 19, 2012 | 01:42 PM
maharajamd's Avatar
The seal probably just has tiny little rubber tabs that kind of slip in and out of the metal with pressure. Literally pull out till they pop out, push in till they pop in.
Old Mar 19, 2012 | 02:48 PM
KN_TL's Avatar
I don't even think there are tabs. The gasket has a slit that slips over a metal protrusion. No glue or anything.
Old Mar 19, 2012 | 02:50 PM
antkn33's Avatar
Does any one have a link to that part? I looked a several web sites but it is like finding a needle in a haystack. And the descriptions aren't that intuitive.
Old Mar 19, 2012 | 03:08 PM
maharajamd's Avatar
http://www.acuraoemparts.com/delray/...All&vinsrch=no
6 and 9, 7 and 10?
And now that I think about it I believe they have like little christmas tree tabs that go into the metal, then the weatherstripping has little holes that need pulled over them. At least that's what I remember.
Old Mar 19, 2012 | 03:15 PM
antkn33's Avatar
No, I mean the seal that attaches to the body of the car not on the door itself.
THanks
Old Mar 19, 2012 | 03:35 PM
maharajamd's Avatar
THanks
Hell I don't know. I couldn't find anything and I looked for 15 minutes.
Old Mar 19, 2012 | 09:42 PM
maharajamd's Avatar
http://www.oemacuraparts.com/find-pa...LLAR%20GARNISH
Old Mar 20, 2012 | 06:39 AM
antkn33's Avatar
Arg. $67 for some rubber?? I was told they be more like $25-30. Bummer.
Old Mar 20, 2012 | 07:38 AM
maharajamd's Avatar
Yea I noticed they were pricey. Possibly because they don't really sell a lot of them?
Why do you need one anyways? That kind of item I'd just find a crashed TL or head to a junkyard...
Old Mar 20, 2012 | 07:51 AM
antkn33's Avatar
I bought a used 2005. The seal around the door opening is badly worn, even split in some areas. I noticed some wind noise from the door so I thought I would try replacing it.
Old May 21, 2012 | 01:48 PM
summerayu's Avatar
I had the same problem, not that badly worn though. BTW, were you able to replace it?
Old May 22, 2012 | 09:05 PM
TVL65's Avatar
Mine is worn too, even cracked/split apart. My jackets must be rubbing when I get in & exit the car.
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
tman570
Jun 11, 2019 07:56 AM
hand123
Sep 10, 2015 09:29 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
