Replaced window motor, now…
A while back I replaced the window motor in the front passenger door on my 2006 TL. Now it works smoothly again but does not roll all the way up or down after a long button touch like it did before. Is there a programming trick that will fix this?
John
John
Thanks for the info
Before I go into the oven outside I’ll ask for clarification. I’m assuming that where it says drivers (passenger) I should use the passenger option. But should the window switch that is operated be the one on the drivers door, or the passenger door.?
