Replace A/T driveshafts.. Help. DIY ??
Old Jun 9, 2012 | 01:32 PM
mattyd6911's Avatar
How do the inside(tripod) mounts detach from the car? Ive taken the hub nuts off before, thats no big deal, but never the whole driveshaft. Anyone have an illustrated DIY ??
Old Jun 9, 2012 | 02:56 PM
Turbonut's Avatar
Left side-pry the inboard joint from the trans
Right side-drive the inboard joint off the intermediate shaft
https://acurazine.com/forums/showthr...8#post13001718
Old Jun 9, 2012 | 03:13 PM
mattyd6911's Avatar
Thanks. Is there a retainer clip or anything that holds it in? You happen to have any pics
Old Jun 9, 2012 | 03:53 PM
Turbonut's Avatar
If memory serves me correctly, snap ring on left D/S where splines enter trans, the snap ring on the right side is on the intermediate shaft and the D/S slides over the snap ring. There are other snap rings at the joints, but I don't assume you're asking about them.
Google is you friend as you can call up illustrations and take a look.
Old Jun 9, 2012 | 04:20 PM
mattyd6911's Avatar
Does the tranny fluid need to be changed if the passenger side driveshaft does, or is that only if you replace the intermediate shaft?
Old Jun 9, 2012 | 05:05 PM
Turbonut's Avatar
On the right side, the intermediate shaft that enters the trans is not removed, so no problems with trans fluid.
Old Jun 9, 2012 | 06:33 PM
mattyd6911's Avatar
Thanks again
cycdaniel
Dec 17, 2019 10:58 AM
Pegon95
Sep 15, 2015 01:54 PM
gqdabien
Sep 8, 2015 11:41 PM
ellisd03tls
Sep 8, 2015 04:17 PM
yahelou
Sep 6, 2015 09:12 PM
