Removing sticker from glass
The quick-lube place I went to put a sticker on my windshield to remind me when the next oil change should be. I tried peeling it off but it does not want to come off easily. What is the quickest/easiest way to get it off? A soap-water mixture?
first nick a corner of it using your fingernail and try to peel it up. Then remove the glue slowly with goo-gone. Make sure that you don't get it on the headliner or pillar.
Registered but harmless
Received 1,150 Likes
Actually, if you have some rubbing alcohol around, put that on a piece of felt or shop towel and it should take off the residual adhesive if there isn't too much.
There is a tint goo remover that I saw at an autostore once -- basically turned out to be a goo gone product...
when i had to remove my front tints... goo gone too a little too much effort to get the crud off, and therefore +10 on the singe edge razor... as that little guy just ate through all that gunk -- took about 20 of 'em as they dull easily.
Well I finally got it off. Sat in my car and decided not to come out until it was gone no matter what.
The problem was I had been applying goo-gone over the sticking expecting it to disolve it but that didn't happen, goo-gone is meant for the sticky stuff. So I scratched away at the sticker with a quarter until only the glue was left then used goo-gone and a paper towel and it came off. Now there is no trace of that sticker.
And if anyone puts a sticker on my car again I'm gonna kick them in the pants.
rcs86
08-02-2016 06:52 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
