Rear left bumper sticking out a bit below tail light?
My question is do you guys think it's a spacer needed or a broken clip? I'm guessing broken clip because I've removed the two 10mm bolts and attempted to adjust the bumper, but it feels like something on the rear left side under the tail light just isn't catching/securing and the bumper pops right back out once I take the pressure off it as I tighten down the 10mm bolt on that side.
I'm going to take off the entire bumper tomorrow when I have time.
There's a metal bracket directly under the taillamp,but all it really does is clamp down on the bumper and some guys have even removed it completely so they don't have to take out the bumper to R+I taillamps. I don't know if you posted a picture or not, but if it is not sticking out directly under the taillamp,and more so down the side of the bumper, Those spacers are plastic and snap easily. Also, if the car had any work done before, the bumper could be Aftermarket,and just not fit as well as OE.
looks like its just not lined up properly. take it off and reinstall and make sure you line it up properly and all the brackets are intact/lined up. it should push right in no problem.
I might be wrong but to me it might be the bottom corner of the tail light is in too far v/s the bumper being out. Maybe the tail light has been hit and pushed in. Look at the taper at the trunk lid edge.
Looks like you sir are correct! It's an aftermarket replacement tail light and that's what's causing the issue. My buddy and I just had the bumper off and we spent an hour or so trying to adjust/align the tail light just right, unfortunately to no avail. Short of replacing it with an OEM tail light I don't see the left side of the bumper ever sitting perfectly flush.
The top of the tail light doesn't align/sit flush, so the bottom part of the tail light is putting pressure on the bumper and causing it to push out enough to cause the gap. The gap is now only on the side of the bumper, the picture I posted that showed the bumper gap/misalignment under the tail light is now flush and fine. I'm about to go outside and mess with the tail light alignment some more.
Yeah, I'm about to order the black clip piece and see if that helps. It seems to have a little more wiggle room than the clip piece on the right side. As I mentioned before, I have the bumper flush under the tail light now, so it almost has to be something with the clip.
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
Ny1718
Sep 11, 2015 09:21 AM
