Problem with tie down for replacement battery
Old Nov 25, 2007 | 05:27 PM
rvmeush's Avatar
The original battery in my 2004 died with 50K miles on the car - which doesn't seem unusual from some of the posts on battery failure. I'm having some problems finding a replacement battery that will work with the original Acura tie down. My original battery is a Delphi Freedom battery, and the top of the battery is flat (there are no water plugs). I can't seem to find a replacement battery other than Optima (which is overly expensive) that fits the Acura and has a flat top.
Can someone recommend a replacement battery with a flat top, or tell me what to use for a battery tie down? I'm sure that others who have replaced their batteries have faced this problem but I haven't seen it discussed in any postings that I could find.
Thanks.
Old Nov 25, 2007 | 09:16 PM
csmeance's Avatar
go return the battery, and go to the stealership. They should warranty the battery as it was 2 years for the 2004-2006 TL, or they should pro-rate a new one with a 3 yr warranty standard.
Old Nov 25, 2007 | 09:37 PM
teomcdohl's Avatar
Admiral Crunch
Optima FTW. It's worth the money.
Old Nov 26, 2007 | 12:37 AM
MR1's Avatar
MR1
05/5AT/Navi/ABP/Quartz
Do check your original warranty, it's a good one.
I didn't check so went to Sears and bought their Gold Series. It fits fine with the original tie down which is adjustable.
Old Nov 26, 2007 | 08:14 AM
DMZ's Avatar
DMZ
Head a da Family
https://acurazine.com/forums/showpos...38&postcount=4
Old Nov 26, 2007 | 11:55 AM
MR1's Avatar
MR1
I reacted before I thought. Typically when my battery cranks slow twice in a short period, off to replace it I go.
Sears had been good with DieHard batteries for the past 40 years for me. This last experience was the final one as the service was terrible (K-Mart).
#24F and bestbuy were the keys from your post DMZ.
Old Nov 26, 2007 | 12:42 PM
Tripnbeats's Avatar
i got a stock one with a kinetic power 200cap supply for the system.
Old Oct 4, 2008 | 03:31 PM
sim97124's Avatar
What did you end up doing with your battery?
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
