PO137? 02 sensor circuit low voltage?
Old Sep 19, 2013 | 07:51 PM
breck569's Avatar
Hi everyone, I have a check engine light that came on soon after i installed pcd.
I checked the code today and it says
PO137- Powertrain. 02 SENSOR CIRCUIT LOW VOLTAGE (bank 1 sensor 2)
I tried looking around, but it seems that this code is not so common.?(I have defoulers; have not tried adjusting them.)
Old Sep 19, 2013 | 07:57 PM
breck569's Avatar
i should also mention that the car hasnt been driving very well lately. feels real sluggish, even with no weight
Old Sep 20, 2013 | 05:54 AM
Jspec9's Avatar
MeelzJaw Auto Service
Im not to familiar. What are you referring to when you say "pcd"?
You might have to check the wiring to the oxygen sensor to make sure there is proper voltage going to the sensor.
Old Sep 20, 2013 | 01:44 PM
breck569's Avatar
Pcd- pred cat deletes
Today I looked behind engine and could faintly see that the wiring for the sensor must have gotten burned by a hot component. I just hope I won't have to take out the whole precat to take off sensor.
Would it be a bad idea to solder wires back together? Or buy a new sensor. Anyone?
Old Sep 22, 2013 | 12:12 AM
Jspec9's Avatar
id say just replace the sensor
Old Sep 22, 2013 | 01:26 AM
pohljm's Avatar
Soldering should be fine
Old Sep 22, 2013 | 01:40 AM
vietxquangstah's Avatar
bank 1 sensor 2 is the oxygen sensor on the downstream side. I don't think you would be able to see the wiring for that o2 sensor unless your under the car.
The o2 sensor you saw was probably sensor 1 which is upstream.
Old Sep 22, 2013 | 10:10 AM
paperboy42190's Avatar
i believe a GOOD solder will give a wire its original strength back. you will need to remove the sensor to do a proper soldering job though. should be removable with a wrench
Old Sep 22, 2013 | 10:16 AM
Turbocoop's Avatar
You can also get some heat resistant wire loom to go around it just to be safe. I didnt get any CELs when I put my PCDs in, if its the downstream O2 sensor, which it sounds like it is- you might want to just try to adjust the defouler. I have mine tilted straight up at a 90 degree angle towards the top of the PCDs, if that makes sense.
Old Oct 1, 2013 | 11:54 PM
breck569's Avatar
Ill go ahead and remove the precat and try soldering, and reinstall and take my time making sure wires are clear of hot metal. Can a bad secondary o2 sensor cause any problems? If so ill try to get it fixed this weekend, otherwise im going to wait untill december when i have more free time.
Old Oct 4, 2013 | 11:14 PM
I do not believe a faulty downstream sensor will cause any problems. The downstream sensors are mainly there to monitor catalyst efficiency. It doesn't play a huge role like the upstream does when it comes to fuel trim
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jamus22
Jun 11, 2023 10:08 AM
RobbDizzle
Oct 15, 2015 11:16 AM
hrothgar02
Sep 28, 2015 11:08 AM
Rcelestino93
Sep 23, 2015 10:01 PM
