Please help
Old Nov 21, 2015 | 12:01 PM
Brji2369's Avatar
3rd Gear
Please help
I just changed the timing belt kit on my 04 TL and everything sounded good after it was done i drove home and it was about a 30 min drive and it was running smooth and once I arrived home I realized my power steering pump was overflowing alot and know my steering wheel is very stiff. I tried leaving the car on for a while and tried moving the wheel buts it's really stiff
Old Nov 21, 2015 | 12:20 PM
mrmako's Avatar
Someday, an RS6 Avant+
This is probably better in the 3G TL forum.
Third Generation TL (2004-2008) - AcuraZine Community
Sounds like whoever did the work left the cap off of the PS reservoir and the fluid went everywhere. So loss of fluid = loss of power steering.
Old Nov 21, 2015 | 12:51 PM
neuronbob's Avatar
Moved from Car Talk to 3G TL Problems
Old Nov 21, 2015 | 12:54 PM
Brji2369's Avatar
3rd Gear
It had the cap on
When I parked it even with the cap on it was overflowing
Old Nov 21, 2015 | 01:48 PM
MonkeyTrucker's Avatar
Life Connoisseur
Likely pulling air in from somewhere. Maybe they didn't re-tighten the inlet hose connections, or cracked a hose. Could have even dropped the o-ring gasket or not notice it missing when reinstalling.
I'd confirm with the mechanic what they removed in relation to the power steering pump and components...I assume someone else did the work since you state that you "after it was done i drove home."
charmer37
Dec 5, 2015 06:27 PM
copmagnet82
Nov 5, 2015 01:17 PM
orangewhip
Nov 2, 2015 12:58 PM
stefce
Oct 29, 2015 10:10 PM
