Periodic rev drops at idle
Old 01-03-2023 | 09:03 AM
PgLgGrg's Avatar
Recent issue. Revs drop way below the 800rpm periodically.
if I give it a decent rev, 2k plus, and if the lights are on, they noticeably get dimmer as the rpm drops to 600…almost like a battery issue.
it’s on a brand new battery (good voltage)
issue persists if I take out the fuse 7 (which is a source of 350mA parasitic draw at idle..a different issue).
Most common searches indicate that it is a bad idle air control valve. Could it also be anything to do with having a leak in my intake hose?
FOund this video which is a good source, if this is the issue.
Seems simple enough, though time consuming. Any ideas if this is the most probably cause?
Old 01-03-2023 | 11:52 AM
twokexlv6coupe's Avatar
A vacuum leak ANYWHERE on the engine (not specifically the intake hose) will cause some erratic and funny idling situations. Sometimes harder to diagnose via smoke tester if the hose is completely hidden, but sometimes the fix is easier than replacing the IACV.
So if you're smoke test results are negative..... I'd look at the IACV.
Old 01-03-2023 | 01:30 PM
PgLgGrg's Avatar
I did crack my intake tube a while back. 2 different areas which I patched with duct tape about 4 months ago. perhaps the seal has been opened up from time, or is another issue. I will try to tape her up again and see if there is any change in the idling inconsistency.
Old 01-03-2023 | 02:40 PM
Just an FYI, the car in the video above is a (J32A1) 2g 2001 TL.
If you have a DBW (J32A3) 3G 2006 3.2L Base, w/ Navi, I'm pretty sure you don't have an idle air control valve.
Throttle Body - 2006 Acura TL 4 Door BASE KA 5AT (acurapartswarehouse.com)
Could your app sensor be faulty?
Old 01-03-2023 | 02:57 PM
PgLgGrg's Avatar
Oh boy, so many possibilities. Thank you for pointing that out. I would be livid going through all that work and discover no valve is present in the car lol. I will see if sealing my cracked intake tube better changes anything to eliminate that first.
Old 01-03-2023 | 06:18 PM
csmeance's Avatar
did you do the idle relearn after new battery?
zeta (01-04-2023)
Old 01-04-2023 | 04:03 PM
PgLgGrg's Avatar
Hehe, it’s always the simple solutions that fix thing huh?
you were correct and tried this last night and idle has been fixed. Thanks very much, it’s weird that a car would have to relearn idle, but I’m new to the car scene, so obviously lots to learn!
Old 01-04-2023 | 05:32 PM
Chad05TL's Avatar
I was getting a low idle and somewhat unstable.. Then I added 1 can of BG 44K to the fuel tank. And totally solved the problem. Now when I sit at a stop light, my car is pulling harder and consistently.
paperboy42190
10-22-2013 11:05 PM
reaper101
04-17-2013 01:59 PM
EvilJoker
08-17-2012 11:20 PM
broly
06-30-2008 10:24 AM
Quick Reply: Periodic rev drops at idle
