PCV Valve broke
Old Oct 22, 2018 | 06:29 PM
ThatBlackTL's Avatar
PCV Valve broke
Hey guys,
So I was changing the pcv valve and while trying to get it out, the top cover of the pcv broke and now the valve is stuck. It didn't fell into the valve cover, it's just stuck there.
Is there any way to get it out other than towing the car to a mechanic?
Thanks.
Old Oct 22, 2018 | 06:30 PM
needle nose pliers
Old Oct 22, 2018 | 06:32 PM
needle nose pliers
Thanks for the suggestion. I'll try that.
Old Oct 22, 2018 | 07:07 PM
Well, I tried the nose pliers but there is nothing to hold on to. I'll post a picture.
Old Oct 22, 2018 | 07:15 PM
Stick the needle nose pliers closed into the valve and then open it to "grab on" and then pull it out.
Or alternatively, you can buy a set of internal pipe wrenches, stick the proper size in and expand and then pull
https://www.homedepot.com/p/General-...39-4/301371197
Old Oct 22, 2018 | 07:16 PM
There are multiple threads about broken PCV valve here you can look through for some ideas:
https://www.google.com/search?q=pcv+...hrome&ie=UTF-8
Old Oct 22, 2018 | 07:17 PM
Alright. I'll try that. Thank you.
Old Oct 25, 2018 | 04:02 PM
Update:
I got it out. The internal pipe wrench I ordered wouldn't fit, not even the smallest one. But I read on a Honda pilot forum that a 7/16-14 tap would perfectly fit in the pcv hole and it worked.
Old Oct 25, 2018 | 04:06 PM
thanks for the update. Now when it happens to someone else, they can think to use that too
Old Oct 25, 2018 | 04:07 PM
Yeah. Thank you for all the suggestions.
Old Mar 14, 2022 | 10:47 AM
Bobman85's Avatar
Pcv stuck
Originally Posted by ThatBlackTL
Update:
so sorry just had mine break off inside my valve, any positive things I can do to get this out without making things worse
Old Mar 14, 2022 | 02:59 PM
did you try that tap??
Old Mar 14, 2022 | 05:52 PM
94CivicSi's Avatar
I broke it on my Pilot. I had some lag bolts left over from a porch project that were just the right size. really coarse threads to grab the plastic. i didn't have to thread it in far to get a good purchase and pull it out. Even if you don't have something like that on hand, easy to find at a local hardware store.
nats007
Jun 29, 2021 01:20 PM
TCM 01 CL-S
Dec 6, 2007 05:29 PM
sundance_gold
Aug 26, 2004 07:23 PM
sundance_gold
Jul 12, 2004 08:56 AM
athlonxp
Mar 4, 2003 05:59 PM
