PCV Valve question
Old Jul 12, 2004 | 08:02 AM
sundance_gold's Avatar
PCV Valve question
Hey all,
I'm trying to diagnose a symptom and I think it might be the PCV valve. The car sems to be idling rougher than usual and a recent oil change did not solve the problem as it used to in the past.
1). Where do I find it?
2). If I remember from other cars, if you shake it and you can't hear a rattle-like sound, that means its bad, right?
3). If its not the PCV valve are there any other filters that could be causing the car to idle like this? I know its not new (72K) but up until now after every oil change I noticed that it would behave like a "new car". I refer to it as dirty diaper symdrome--whereby the car would behave like new after getting its diaper changed. I had the throttle body cleaned last year (from carbon build-up) and other fluids look fine, as do the belts.
Thanks for your advice!
Old Jul 12, 2004 | 08:37 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Did you try to use a fuel injector cleaner? have you ever replaced the spark plugs?
Old Jul 12, 2004 | 08:56 AM
Yes, I've used several bottles of fuel injector cleaner with minimal effect. I was having a problem with the car stalling--just after starting-- and the fi cleaner fixed this issue. No, haven't changed the plugs--since I thought it wasn't necessary before 100k miles.
Is it an easy DIY to change the plugs?
I'd almost say that if its not a clogged filter that it does need a tune up.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
06TLMatt
Oct 2, 2015 08:14 PM
navtool.com
Sep 25, 2015 05:15 PM
