Overheating and No Coolant Drawing
Old Aug 24, 2019 | 01:57 PM
Andres Morejon's Avatar
Hello, my sister's 2006 Acura TL is having a common overheating problem. Seems that after I fill up the radiator it's fine for a few days and then resumes overheating or visible leak. There is no white smoke in exhaust or milky oil. I have replaced the fan and its relays as well as the thermostat. The reservoir is full of coolant but I have never seen the car draw from the tank. Any tips would be greatly appreciated! Thank you
Old Aug 24, 2019 | 09:10 PM
t-rd's Avatar
You might have a stuck shut thermostat. Only way to find out is the drain the coolant and test or replace the thermostat.
Old Aug 24, 2019 | 10:31 PM
How would I test? I just replaced the thermostat 3 days ago so I am not really sure. Is there anything else you might think?
Old Aug 24, 2019 | 10:35 PM
GhostTL09's Avatar
Yikes
Old Aug 24, 2019 | 10:49 PM
peter6's Avatar
So you need to refill the coolant or car overheats?
If you want to test your thermostat:
Old Aug 25, 2019 | 09:04 AM
t-rd's Avatar
You need to take it back out to test it like in the above video.
What thermostat did you use and did you bleed the system properly?
Old Aug 26, 2019 | 10:22 AM
Nytetime6's Avatar
I had the same issue, it ended up being a bad Heater Control Valve.
Old Aug 26, 2019 | 12:19 PM
peter6's Avatar
Bad heater control valve? You mean that it was leaking?
Because if it was stuck then there's no way it should cause overheating condition.
Old Aug 26, 2019 | 01:30 PM
awoc's Avatar
There's a coolant bleed nipple on the block. Crack it and see if any air comes out. Most likely you have some air in thr line. Also if the pump is doing it's job, you should see a good stream out of it.
Old Aug 26, 2019 | 03:07 PM
Nytetime6's Avatar
Yes, the Heater Control Valve was leaking.
Old Aug 28, 2019 | 09:31 PM
t-rd's Avatar
You wouldn't crack the block drain to let air out, even while the engine is running. Because that drain screw is by the rear of the block, having coolant squirt in your face lying down there watching it while you crack it open is silly. Just leave the radiator cap open and run the engine until the fans come on to bleed air, with heat turned to max to open the heater core.
I don't see how a bad heater control valve would cause engine to overheat, it just controls coolant flow to the heater core. The heat flowing into the cabin would be broken
Barmaley
Jul 8, 2017 02:15 AM
greydog
1G CL DIY & FAQ
Oct 19, 2015 07:57 AM
jaw5983
Jan 22, 2014 05:08 AM
duvaL32TL
1G TL Problems & Fixes
Feb 5, 2007 06:25 AM
732xghost
Sep 21, 2006 10:00 AM
