"Tighten Fuel Cap" message and throttle response issue
Old Aug 26, 2019 | 03:48 PM
vinuneuro's Avatar
My 08 TL is at 75,000 miles and I've been intermittently getting the 'tighten fuel cap' message. I replaced the cap before learning that there is a common issue with the Purge Control Valve, and of course the new cap didn't solve the problem.
I've been getting this message again recently but there is some drivability issue as well. Pulling from a stop there's a slight lag when pushing the pedal and during driving as well. This throttle response issue comes only when I get the gas cap message.
Does the purge control valve typically cause any other issues other than the dash message? I'm wondering if it might be some other issue in this case.
Old Aug 27, 2019 | 09:41 AM
BreezyTL's Avatar
Make sure the cable to the APP sensor is adjusted correctly or the sensor could be faulty. I just replaced mine due to failure and the car is very responsive now.
Old Aug 29, 2019 | 12:59 AM
xedap1998's Avatar
Check for Broken hose. The same hose that feed the the purge sensor
SHUJeff281
Aug 28, 2019 09:04 PM
grandlaker
4G TL Problems & Fixes
Sep 25, 2017 01:51 PM
liljojo4711
Nov 23, 2014 10:07 PM
withoutcomp1
Dec 10, 2011 03:31 AM
Sidewayz
Aug 2, 2006 06:39 AM
