Please help:coolant resevoir
Old Feb 4, 2007 | 08:16 PM
duvaL32TL's Avatar
Theres steam coming out from the coolant resevoir whats that mean?
Old Feb 5, 2007 | 06:25 AM
TexasHonda's Avatar
It may indicate the coolant is overheating and releasing into the reservoir due to radiator cap overpressure, or radiator cap could be faulty. It could also mean that exhaust gases are leaking past a bad head gasket. You should be overheating slightly.
Top coolant level in radiator and reservoir and check coolant level for changes. Try removing radiator cap while dead cold and examine coolant in radiator for bubbles shortly after startup. If you get a lot of bubbles, a leaking head gasket is likely.
good luck
Gigolo
1G CL Problems & Fixes
May 29, 2014 05:35 AM
bmw12345
Feb 10, 2014 05:43 PM
kcin920
May 12, 2011 06:03 PM
Palayah8ta
Dec 2, 2008 11:26 PM
bradykp
Jan 23, 2006 10:15 AM
