Help Needed (chitlins/hayes owners)
Old Nov 24, 2008 | 03:55 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
I need to replace my Clutch Master Cylinder tonight..
Does anyone have the manual so i can get pictures to go along with the DIY?
That would be super life saving..
this is what i stole form H-A.Net DIY:
Originally Posted by white_n_slow
Hey everybody! I just replaced my clutch master cylinder today, and I thought I'd go over the procedure, in case anybody is wondering. If your master cylinder is leaking, and you're worried about doing it yourself, dont fear!
Step 1
Drain clutch hydrolic system.
To do this you take the little rubber cap off the bleeder valve located on the slave cylinder (on the front of the tranny by the radiator). You open up the valve with an 8mm wrench and put a hose on the valve. Put the other end of the hose in a pan to collect the brake fluid. With the cap off the MC resevoir, it'll drain pretty quick.
Sep 2
Disconnect the resevoir and hydrolic line.
To disconnect the resevoir, just unbolt the 2 mounting bolts, loosen the hose clamp and pull it off. To disconnect the hydrolic line just unbolt the flare nut on the top of the MC and pull it out. It might help to use a little penetrating lube for this one. At this point you'll want to prop the hydrolic line somewhere out of the way... the brake MC vacuum hose works well for this.
Step 3
Under the dash.
Pry out the cotter pin that holds the cluth pedal pin in the pedal and pull out the pedal pin. A needlenose pliers should help here. Then unbolt the 2 clutch MC mounting nuts.
Step 4
Pull it out.
Go up front and just pull it out. You kinda have to wriggle it around to do this. If its being tricky, go back under the dash and push on the mounting bolts. No biggy.
Step 5
Put the new one in.
Step 6
Back under the dash.
Bolt up the MC mounting bolts and put the clutch pedal pin back in with a new cotter pin. At this point you'll want to apply grease to the MC pushrod and the pedal pin.
Step 7
Reattaching everything.
Reattach the clutch hydrolic line. Attach your new resevoir and hose with a hose clamp
Step 8
Refill and bleed hydrolic system.
Fill the resevoir with DOT 3 or 4 fluid (but don't mix), put the cap on, and pump the brakes for a few seconds. Take off the cap, top off the resevoir again and pump the pedal a little more. You'll need to do this a few times until there is no more air in the system.
Thats it, you're done! The whole process took me a touch over an hour, and all I paid was $60 for a used MC with resevoir. Considering the shop quoted me $205 for this job, I'd consider it well worth DIYing. It really wasn't hard at all. The only thing to look out for is being careful with your brake fluid, as it can screw up any painted surfaces and is really nasty to mother earth if you spill it. Hope this helps! .
Old Nov 24, 2008 | 06:20 PM
Cocoa's Avatar
2600lb CL
Call Mauricio you lazy ass! Or have him do it...
Old Nov 24, 2008 | 07:52 PM
SupraManAG's Avatar
One custom CL
damn man where have you been?
Old Nov 24, 2008 | 08:37 PM
disgruntlednut's Avatar
01 Type-S, Sexy Silver
Sorry, I know this isn't any help, but I can't stop laughing at "chitlins"
k, hopefully someone more helpful than me will come by now.
Old Nov 25, 2008 | 01:11 AM
Palayah8ta's Avatar
Ciao Pho Eva eva
sorry ive been MIA for a while.. my car is a mess.. shit like this keeps happening to me..
chris, ill call mau tomorrow, but how am i going to get my car to corona?
Old Nov 25, 2008 | 01:44 AM
asianspec's Avatar
hey daniel, im in anahiem hills at eric's place right now. so if you want me to roll with you then its on the way kinda.
Old Nov 25, 2008 | 10:26 AM
Cocoa's Avatar
2600lb CL
Sorry I missed your calls yesterday. I threw up like 5 times last night, and twice this morning. haha I was punished with this banging headache.
Old Nov 25, 2008 | 07:56 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
You go out drinking again? lol..
are u in Texas? or Corona?
JAY,
does texas walker ranger know how to change the Master cylinder?
Old Nov 26, 2008 | 05:44 AM
SupraManAG's Avatar
One custom CL
its no easy task I heard. I real pain in the balls but then again whats easy on our cars
Old Nov 26, 2008 | 08:40 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
true dat
Old Nov 26, 2008 | 11:43 AM
Palayah8ta's Avatar
Ciao Pho Eva eva
BTW with the H-Twinkie in there, there's even less room to operate on this bullshit..
Fuck.. i guesss i need to just pay a shop to rape me..
Old Nov 26, 2008 | 05:07 PM
asianspec's Avatar
g/l man.
Old Nov 26, 2008 | 06:05 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
Good new guys!!!! No shop wants to work on my car because of the holiday!!!! THANK YOU TURKEY GENOCIDE DAY!!!
Old Nov 26, 2008 | 10:14 PM
(Mid-Atlantic)
TGD!!!!
Old Nov 26, 2008 | 10:32 PM
asianspec's Avatar
sorry to hear that.
Old Dec 2, 2008 | 10:00 AM
Cocoa's Avatar
2600lb CL
Did you call Mauricio? He can do it...
Old Dec 2, 2008 | 11:34 AM
Palayah8ta's Avatar
Ciao Pho Eva eva
He's supposed to come over tonight to fix my scrapper...
Old Dec 2, 2008 | 11:26 PM
Cocoa's Avatar
2600lb CL
Told you he'd do it.
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
Feb 25, 2020 09:57 AM
C2CuSn07 TL
Sep 11, 2015 06:54 PM
asahrts
Sep 4, 2015 05:55 PM
nuldabz
Sep 3, 2015 05:49 PM
