oil life
oil life
seems like 100% takes like 7k miles before it tells you need an oil change, i thought oil should be changed at 3k miles?
definalty seems like it wait way longer then 3k?
ami right?
or does synthetic last alot longer?
ami right?
I just had my 07 TL-S changed the oil, and it was after 6,912 miles... about over 7 months since my last oil change... just go with what your MID tells you
AZ Community Team
Received 7,770 Likes
Mine has been running at ~4500 miles per change.
Oil Life counter takes into account temp, RPMs, miles and other data to estimate oil life. Your oil life will depend on your driving conditions.
3k per oil change is old technology thinking. Oils are better formulated to last longer and engines are better engineered to reduced oil "wear". Even a basic dino oil should be good for 4,000 - 5,000 miles.
A good filter goes a long way to helping make sure your oil lasts as long as it should.
IBankMouse
06-13-2020 12:53 PM
