No heat at idle
Old Jan 19, 2016 | 06:55 AM
rbailey86's Avatar
No heat at idle
Hello,
This is my first winter with my 08 TL.
I have no heat at idle. Can warm up for 30 minutes, cold as an ice box. Once I rev it up or accelerate I get heat.
I am in the auto business. So I checked the basics. Coolant full, no leaks, bled system, no air.
Obviously I am going to replace the thermostat next. Just curious if their are common issues I should look for, this is my first TL.
See attached picture, that's after 45 minutes, is that proper temp for this vehicle? thanks
Old Jan 19, 2016 | 07:35 AM
rbailey86's Avatar
never gets to halfway point always just below
Old Jan 19, 2016 | 08:03 AM
Jackass's Avatar
If I am recalling correctly, there is a Heater Control Valve that sticks at times and may be worth checking.
Old Jan 19, 2016 | 08:33 AM
rbailey86's Avatar
will look into it thanks
Old Jan 19, 2016 | 09:15 AM
nfnsquared's Avatar
https://acurazine.com/forums/third-g.../#post11381436
Old Jan 19, 2016 | 09:40 AM
rbailey86's Avatar
acura service said "no common issue try the thermostat" no mention of the HCV. oh well.....might as well do both I guess
Old Jan 19, 2016 | 10:11 AM
Acurazine has been much more reliable over acura most of the time
Old Jan 19, 2016 | 10:33 AM
Jackass's Avatar
My theory on this is if the engine itself is up to temp and behaving normal, the thermostat "may" not be the primary suspect. If only the heat is acting up, the prime suspects would be an air bubble or the HCV.
Old Jan 19, 2016 | 11:19 AM
rbailey86's Avatar
thermostat going in now. will see how it works out
heater control valve works. when I switch between hot and cold the lever attached to cable does move so I doubt it is stuck or restricted so not thinking HCV
thermostat/air in system im hoping
Old Jan 19, 2016 | 01:33 PM
rbailey86's Avatar
as of now thermostat and "bleed" seemed to fix issue, heat at idle now. time will tell tomorrow morning when its freezing out. it was 65 in shop.
the coolant temp read 200F prior to replacing thermostat so may not always be able to go by that
Old Jan 19, 2016 | 02:58 PM
truonghthe's Avatar
FIY the arm on the lever might works but the plastic valve on the inside could be broke off the arm therefore you can see movement on the out side but on the inside the valve does not open at all.
Old Jan 19, 2016 | 03:01 PM
rbailey86's Avatar
good point. its in a pain in the as* spot. will know later if its fixed have it sitting outside in 25 degree weather will let it warm up 20 mins
Old Jan 19, 2016 | 04:04 PM
nfnsquared's Avatar
Yeah, I would've thought the same..
Color me surprised...
Sub'd for final outcome.
Old Jan 20, 2016 | 07:10 PM
truonghthe's Avatar
inspect the inside water valve, if its good then you might want to see if the heater core get some short of clogging. Eric the car guy has great DIY on how to unclog/flush heater core.
TyB
1G RDX Problems & Fixes
Jun 27, 2017 04:23 PM
not_a_doctor
Mar 19, 2016 10:17 AM
haha0002
Jan 12, 2016 07:39 PM
upset
5G TLX Problems & Fixes
14
Jan 7, 2016 01:20 PM
