Multiple electrical issues (headlights, windows, radio)
Old Dec 11, 2017 | 09:15 AM
Brodric's Avatar
2004 TL base non-navi
128k auto
Shortly after purchasing the car, the radio would cut on and off when I hit bumps. One day I hit a bump and the radio never turned back on, the whole display being just dark/blank.
A couple months later, my headlights started acting funny, driver side wouldn't turn on always, I'd turn them off and back on again, and sluggishly the light would turn on. Well lately, it's been either one or the other not working, and sometimes neither. Once in a while I'll get in and they both work.
2 days later, none of my windows will function, whether I use the switches on my driver side door or if I manually press each individual window switch. I'm curious if these problems are somehow connected, resulting back to the radio cutting in and out. Any input is greatly appreciated, been trying to look at these problems one at a time but can't help but believe there's just a big problem with the car. Thanks!
Old Dec 12, 2017 | 01:14 AM
Will Y.'s Avatar
Registered but harmless
128k auto
A couple months later, my headlights started acting funny, driver side wouldn't turn on always, I'd turn them off and back on again, and sluggishly the light would turn on...
You have an intermittent electrical connection issue, which sounds like a bad ground wire connection somewhere.
Also check the battery clamps and cables at the ground and starter ends too.
Welcome to AZ.
Old Dec 13, 2017 | 11:12 AM
Brodric's Avatar
128k auto
Welcome to AZ.
Thanks for the input, forget everything about the windows, they're fine. But I don't know I feel like we checked the grounds well, will again. But is that a logical reason for why the opposite headlight turns on? Very rarely both at the same time. Sorry for so many questions it's just 10 degrees outside and would rather have a better understanding. Full manual should be here any day and will help immensely. Thanks
Old Dec 13, 2017 | 11:56 AM
Bad battery can cause issues too.
With the cold temps also exasperating said issues.
cellph titled
Dec 21, 2021 01:22 AM
Guademate
Dec 16, 2015 07:52 PM
cipher9878
Dec 20, 2014 10:10 PM
HeloDown
Oct 17, 2013 07:38 AM
Comet2404
Jan 21, 2011 02:44 AM
