misfires
Old Nov 29, 2010 | 02:32 PM
  #81
Opel's Avatar
You need to do a compression test and stop the guessing....that will point out to 2 things...ur bottom end, or you're heads.
Removing the oil cap while idling, have you noticed any excessive steam/smoke come out?
Check that out..
Something tells me it ain't the heads/valves. Sorry but just preparing you.
Old Nov 29, 2010 | 02:39 PM
  #82
AckTL05's Avatar
Former Sponsor
If its just the 5-6 cylenders, swap coils from good ones or buy new ones and see if it goes away, it could be bad coils/spark plugs.
I would defiantly get a compression test.
Also from putting on the TURBO and doings your WOT runs and testing the tune could have pushed the valves over the edge, this is what ACURA does at 105k. I know when my app sensor was going the FIC just pushed it over the edge. When modifying cars maintenance should be done 2 times sooner than normal from the extra stress being put on the engine.
What kind of fuel management do you have? What kind of after market fuel pump and what kind of injectors?
Old Nov 29, 2010 | 02:43 PM
  #83
libert69's Avatar
18psi
im doing the compression test now. just typing while on the way to pick up the gauge
Old Nov 29, 2010 | 03:06 PM
  #84
Inaccurate's Avatar
Originally Posted by Majofo
Possibly EGR Valve is open..
Great point. The 3G is known to have issues with the EGR valve going bad. A bad egr will cause rough idling. Bert, do a Acurazine search on "egr".
Originally Posted by libert69
I have my oem plugs here so I can always swap them
I highly recommend this as a test. Your current plugs might be dogged-out from the frequent boost. Put the oem or other new plugs in the car to see if this elimantes the roughness and cel.
now im gettin a very little amount of white smoke from the rear of the motor near the firewall.
My first reaction is that the smoke in unrelated. Check your AN fittings and other fittings that you added for the turbo install.
Old Nov 29, 2010 | 03:25 PM
  #85
Inaccurate's Avatar
a/f at idle bounces between 14.6 and 15.3. Ive always seen those numbers................The weather just dropped to a steady 35 and below the past few days.
My car usually idles around 14.0 - 14.7. I am thinking that it might be worth trying to fatten-up the idle (and other areas too) to be no leaner than 14.0.
You had been ok with those leaner numbers in the warmer weather. But your cold weather might now be making those lean number to be too lean (misfiring). Worth a try.
Old Nov 29, 2010 | 03:27 PM
  #86
Majofo's Avatar
Old Nov 29, 2010 | 03:46 PM
  #87
phee's Avatar
I got the Shifts
I have never had a valve adjustment and I know I need one. I can hear more tapping then normal over the past month. How do you inspect the exhaust valves?
2nd gen Valve adjustment (same procedure as 3rd gen)
warning: valve clearance on the 3rd generation TL is different than the one in the DIY above
heed post #33 (diy) and the post below
Originally Posted by Acura2g
It should be noted that the pictures line up the wrong line for TDC on each cylinder. There is a notch at the edge of the teeth on the sprocket. You can see them in the picture and notice them more when you're doing it. According the HELMS manual you could line up the line on the edge of the teeth. NOT the line in the middle of the sprocket.
Old Nov 29, 2010 | 10:48 PM
  #88
Inaccurate's Avatar
Bert,
Any updates?
Old Nov 29, 2010 | 11:30 PM
  #89
Majofo's Avatar
Old Nov 30, 2010 | 12:09 AM
  #90
libert69's Avatar
18psi
compression test was done. 5 cranks
Cylinders 1-5 were all around 160psi +/- 3 and held consistently. No leaks
Cylinder 6 had 0. Yes Zero. I put a little oil in the cylinder and re-tested. Compression was 30psi and held. Misfires on cylinder 6 only after I drove home.
I should of known something was going on since last week b.c my catch can had filled up EXTREMELY quick. It is a small can and usually takes about a month to get 1/2 full. It took about a week to get 3/4 full.
So I guess we are looking at a cracked ringland. This would explain why the vacuum didnt change.
I guess we atleast know the limits of the pistons on a j32 now. Ill definitely blame this on my increase in boost making well over 400whp. Figure 20% drivetrain loss and we are looking at close to 500 crank hp. No problems for 3 months prior to this with 350 to the wheels.
So Im deciding on my options. Do I swap in 6 new oem pistons and turn the boost down? Honestly, I really dont want to. I want to go up, not down
So I think for the time being the car will be out of service until I get a set of custom pistons from Rodney
Old Nov 30, 2010 | 12:15 AM
  #91
Majofo's Avatar
Sounds like a good excuse for new pistons with a deeper top ring land. You should scope all cylinders.. I figure all of the top rings / ring lands should be showing some initial wear.
Old Nov 30, 2010 | 12:25 AM
  #92
Opel's Avatar
Exactly what I feared..
I don't think you should slap new OEM pistons...I think you should get some low compression forged pistons and rings...since you're gonna dig in there, why do it in a way that limits you? So aftermarket forged low compression pistons is what I would do.
As far as #6 cylinder, assuming it gave out...I wouldn't blame anything (we know they're weak) as far as tunning, except for the plugs you tried...Stick with NGK, ive been saying this since i came in this freaking forum. Stay away from the fancy multiple-spark blah blah blah. They don't work, but you already know that now.
So the plugs you tried, fouled out, caused preignition/detonation, and that's all it takes.
This is something that happened to me with the SC and the supplied plugs from CT...I pulled 3 plugs BROKEN inside, and all 3 cylinders had low compression-broken ring lands
Old Nov 30, 2010 | 12:34 AM
  #93
libert69's Avatar
18psi
Aftermarket is the way to go. Whats your opinions on the stock rods? Are you still using oem? Upgraded pistons is a must, going oem doesnt make sense with this amount of power.
Ahhh yes, zex plugs FTL. Never again
Where did you get your pistons made?
Old Nov 30, 2010 | 12:41 AM
  #94
libert69's Avatar
18psi
This is the spark plug from cylinder 6 last night. Notice the ground strap
Cleaned up. Notice the ground strap again. That crud eventually came off completely. Is that burnt oil?
Old Dec 1, 2010 | 01:20 PM
  #95
ussi's Avatar
I (don't) whine.
First turbo engine to bite the dust? Shitty man, I know the feeling. Not to be a downer but I expected to see this w/ the power u guys are pushing. I think it was cylinder 6 for me too (just got starved?), but the good news is it gives you a reason to upgrade your bottom end. Pinging or not, the rings on the pistons are WEAK, and you might as well change out the rods while you're down there. I ended up going w/ a set of CP pistons w/ a 10.25:1 CR. Their shop is down the street from my work...if you have any questions let me know.
Old Dec 1, 2010 | 02:00 PM
  #96
I hate cars's Avatar
It would be interesting to see if cylinder 6 runs leaner than the rest. If it's an air distribution issue with the intake manfold, it can be corrected.
The extra airflow with the turbo tends to amplify any existing distribution problems. It's common in the TB world for 5 and 6 to run lean. Although it looks crazy, this is the solution, a plate that goes between the upper and lower plenum. With this, detonation tendencies are lowered. I was able to add 3 more psi on pump gas. Some way of modifying the airflow on the TL an be done too.
Old Dec 1, 2010 | 02:33 PM
  #97
Majofo's Avatar
Interesting. The turbo Odyssey has a custom IM. It would behoove the turbo guys to contact them and start a discussion if indeed 5 & 6 are running lean.
Old Dec 1, 2010 | 02:37 PM
  #98
That's a great idea! One you put it under boost, the NA tuning goes out the door. You no longer need or want the 2-stage manifold, the short and long runners, and a "tuned" plenum. All you want is a large open plenum with one set of runners. The larger the plenum the better the chance of equal distribution.
I would go so far as to say the stock intake *might* hender turbo performance and reliability. It's really too bad we can't do a cylinder by cylinder EGT on these cars.
Look at the shape of that plenum, it's not just a straight line. I will be they screwed with it until they got equal distribution.
Old Dec 1, 2010 | 03:05 PM
  #99
Opel's Avatar
My cases were, first time 2-3 and 2nd time 4-6.
Not 6 alone
Old Dec 1, 2010 | 03:06 PM
  #100
Majofo's Avatar
Wilson Manifolds is the mfg for the turbo Odyssey.
http://www.wilsonmanifolds.com/
Might be cost prohibitive but I'm sure they'd do a groupbuy.
kencepeda
Sep 26, 2015 05:13 PM
Chaptorial
Dec 20, 2009 02:14 PM
gtg975n
2G CL Problems & Fixes
May 8, 2007 03:20 PM
ocd_2k3
Sep 25, 2006 01:01 AM
