Mirrors browning/yellowing - Cause? Anyone experienced this or fixed it?
![Name: rDskUhD.jpg
Size: 624.7 KB](https://acurazine.com/forums/attachments/3g-tl-problems-fixes-114/112132d1683167356-mirrors-browning-yellowing-cause-anyone-experienced-fixed-rdskuhd.jpg)
![Name: Hmbq7kd.jpg
Size: 631.1 KB](https://acurazine.com/forums/attachments/3g-tl-problems-fixes-114/112133d1683167356-mirrors-browning-yellowing-cause-anyone-experienced-fixed-hmbq7kd.jpg)
You see the stuff at the bottom of the mirror? This is not on the outside of the mirror. Just wondering if anyone has had this happen before and if there is a fix for it beyond just replacing the glass portion of the mirror.
Common issue! Replace glass piece if it gets to bad
Never use heated mirrors in San Diego and mine have done this. Typically its moisture between the mirror silver and glass
Your Friendly Canadian
Received 1,485 Likes
Get new mirrors and use the heated function only when needed
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Chapter Leader (Mid-Atlantic Region)
mine was worst. after driving around years like that I finally replaced both side last month. Becareful removing the mirror, I accidently broke one of the mirror actuator during the mirror removal process ( lucky parts were not expensive) lol
Unfortunately, leaving the heated mirrors on for an extended amount of time will cause that.
3rd Gear
Changed my diver side a few weeks ago, its faily easy to fix.
Part was 38$ at Acura, and they should have in stock as its a common problem. I had the same problem on my BMW, i think it has something to dowith the heated mirrors and the blue tint. Other cars iv owned that had heated mirrors without blue tinted never had this problem.
I had the same thing happen to me, check out my progress thread, I took a picture of the part number you will need. you can google "acura tl side mirror glass removal" and it will show you how. its real simple.
I've replaced the mirror but came down with a new problem now ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
https://acurazine.com/forums/3g-tl-problems-fixes-114/more-mirror-seat-control-problems-880304/
rockyboy
12-06-2022 02:29 PM
BoricuaTL
04-08-2016 01:08 PM
guitarplayer16
11-29-2015 02:03 PM
