A lot of white smoke from exhaust
Old Feb 3, 2013 | 02:05 AM
bachimik000's Avatar
Well I have a 04 Acura tl and recently a lot of white smoke has been coming out of my Acura tl when I rev is there any solutions to fix it. And here is the video this is my var.
Old Feb 3, 2013 | 02:20 AM
roof2006's Avatar
Looks like coolant to me. That's bad - really bad.
Old Feb 3, 2013 | 02:23 AM
Like how bad. How do you fix it?
Old Feb 3, 2013 | 04:23 AM
vietxquangstah's Avatar
Is this happening in the morning when the temperatures outside are cold?
And coolant means you have a possible blown head gasket.
Old Feb 3, 2013 | 09:51 AM
nismopowerdqg's Avatar
LowNslowTL
are you loosing coolant? check engine light on? does the exhaust smell sweet? car running hot? look in your coolant tank and do you see any oil in it? these are the questions that need to be asked to point you in the right direction, also how many miles on the car?
Old Feb 3, 2013 | 09:54 AM
ez12a's Avatar
the overexplainer
is there any kind of odor associated with it? Some describe it as "sweet" smelling.
Old Feb 3, 2013 | 10:26 AM
The car drives perfect car has 96000miles. There is no check engine and it was recently foggy but when I was with my friends g35 and he was wearing it was.just smoke not white could it be. That I need to change my oil?
Old Feb 3, 2013 | 10:48 AM
Fulani has a TL's Avatar
Video looks like coolant coming out of exhaust to me... When car is cold check your coolant level and report back.
Old Feb 3, 2013 | 11:14 AM
Antifreeze
Old Feb 3, 2013 | 11:15 AM
I put some more on it recently like 2-3 weeks ago
Old Feb 3, 2013 | 11:38 AM
The level didn't move its right in the middle
Old Feb 3, 2013 | 01:27 PM
LowNslowTL
bachi, it sounds like you possibly might have blown the head gasket(s). If its not over heating thats a good thing bc you arnt running as much risk of damaging the motor. take it to a shop asap and they will be able to diagnose this for sure, if this is the case you will need to take the heads off and replace the head gasket(s). its a little more in-depth process then just slapping new gaskets on but thats the gist of it.
Old Feb 3, 2013 | 02:12 PM
Wouldnt there be smoke coming out of the engine if the headgasket was messed up?
Old Feb 3, 2013 | 03:41 PM
pohljm's Avatar
no. headgasket is between combustion chamber and water jackets. you would be leaking water into engine and also oil into cooling system. sometimes you can get exhaust out your radiator if its really bad. If that video is not of a cold start in cold weather then the white vapor would typically be steam from the radiator water that has made its way into the combustion
Old Feb 3, 2013 | 04:56 PM
its was like 40degrees and maybe a little bit foggy but the car drives perfect..
Old Feb 3, 2013 | 05:08 PM
LowNslowTL
cant doesn't necessarily have to drive bad to have a blown hg, could be a small leak but still need to get it taken car of.
Old Feb 3, 2013 | 10:28 PM
Where would I got to get it checked out. And how much does it usually cost to get it fixed.
Old Feb 3, 2013 | 10:46 PM
LowNslowTL
Prices ramge from where you go but expect to pay over $1000 bucks forsure. And you can take it to any reputable auto repair shop or an acura dealer. If you take it to a dealer you will pay more just fyi. Good luck, could be worse!
Old Feb 3, 2013 | 11:01 PM
Could it be that I just started the car and that it was just cold and it didn't warm up
Old Feb 4, 2013 | 12:41 AM
roof2006's Avatar
You mentioned that you had to add coolant. The coolant that you were missing had to go somewhere... Unfortunately, this is as good as you'll get for "diagnose my car for free over the internet." If we can't see it, we can't be 100% sure.
As I always say - DON'T take it to an Acura dealer. Take it to an independent place and pay 30% as much.
Old Feb 4, 2013 | 07:35 AM
LowNslowTL
like roof said we cant be 100% sure but with all the signs and symptoms..it sounds like a head gasket problem, thats why you need to take it to a shop and get a for sure diagnosis.
Old Feb 5, 2013 | 01:15 PM
Could it be that i need to get my oil changed because its just been 3500 miles since i changed could that be causing the white smoke?
And what other affect will i notice in the driving ability?
Old Feb 5, 2013 | 01:57 PM
SharksBreath's Avatar
BANNED
^nothing to do with your oil change. just go to a mechanic and get it checked out.
Old Feb 5, 2013 | 02:03 PM
alexb92's Avatar
It could be moisture being formed from the temperature difference in the exhaust pipes and the air. Typical if its a colder day.
Old Feb 5, 2013 | 03:55 PM
MandoTL's Avatar
Why does it seem like the OP is trying to avoid taking it into the shop to get diagnosed. Just reading down this thread he is trying to find another reason on why his car is doing that.
OP Take it to an indie shop and they will let you know cost and what the problem is. Members here can only go so far in helping you.
Old Feb 5, 2013 | 04:52 PM
I hate cars's Avatar
I'm not on a computer so I'll elaborate later. Water is a natural byproduct of combustion and from the cats. There will always be some water vapor and if the atmospheric conditions are right it will always be visible. With that said I can't see the video.
Head gaskets can blow any number of ways. I've had them where a big blue flame would pop out the side of the engine when it was revved. They don't always blow into a coolant jacket so water loss is not always a symptom. Compression loss will be and in this case if the car is regularly losing coolant I would do a compression test, paying close attention to the plugs. Make sure it's not a slow leak from the small overflow hose first; look for buildup around both ends.
Old Feb 5, 2013 | 05:21 PM
Saw the video, that would be a lot for a dry summer day but not so much on a cold winter day especially if it was just started.
It can be anything from the mentioned headgasket to normal condensation to running rich for any number of reasons. A compression check will put it to rest.
Old Feb 9, 2013 | 02:57 PM
dannyz's Avatar
TLicious Type S
Another good diagnostic is to check for water drops in your oil (on dipstick). Did this get diagnosed by a shop and resolved?
I wouldn't have been laughing if I had seen this coming from my exhaust! Good luck
Old Feb 10, 2013 | 07:20 PM
I've seen worse from a normal car. Not many people bang the rev limiter on what I'm assuming is a cold engine.
Old Feb 11, 2013 | 08:58 PM
dannyz's Avatar
TLicious Type S
Thanks, good info! (& seriously hard on the engine)
Old Feb 13, 2013 | 02:10 PM
xxx_busa's Avatar
its chosen the New Pope, listen Carefully to it !
johnpancakes014
Apr 8, 2016 06:47 AM
IIDXholic
Oct 8, 2015 07:53 AM
Frathora
Sep 28, 2015 11:29 PM
Billu99tl
Sep 13, 2015 11:30 AM
CaliAtenza
5G TLX Photograph Gallery
Sep 9, 2015 06:48 PM
