Metallic dragging sound while accelerating
Your Friendly Canadian
Received 1,485 Likes
^ But he would only hear that when he was braking.
Maybe a bent brake shield?
Most likely the wear indicator on a brake pad is dragging on the rotor. Visually inspect the pads, the wear indicator is generally on the inside pad at the bottom and can be hard to inspect without removing wheels.
Has any service been performed recently? It's usually really easy to determine whats causing the sound if you are familiar with what causes them. I'd say low brake pads or possibly a bent dust shield if a wheel was off recently.
the overexplainer
Yep, if the brake pads are worn enough, the indicators will grind w/ the rotor regardless whether or not you're braking. My sister's civic did the same thing.
kixo
09-25-2015 03:07 PM
AmplifiedDetails
09-24-2015 02:55 PM
