Metallic dragging sound while accelerating
Old Aug 20, 2012 | 11:53 AM
J.Morales's Avatar
My 04 TL makes a metallic dragging/scrapping sound while i accelerate. Any ideas? Thanks for the advice.
Old Aug 20, 2012 | 11:58 AM
from the front or rear?
metallic squeaking or dragging might indicate low brake pad material.
there is a prong that sticks out and once the pad material reaches that prong, you'll get a metallic squeak
Old Aug 20, 2012 | 12:00 PM
Aman's Avatar
Your Friendly Canadian
^ But he would only hear that when he was braking.
Maybe a bent brake shield?
ZOMGVTEK's Avatar
Most likely the wear indicator on a brake pad is dragging on the rotor. Visually inspect the pads, the wear indicator is generally on the inside pad at the bottom and can be hard to inspect without removing wheels.
Has any service been performed recently? It's usually really easy to determine whats causing the sound if you are familiar with what causes them. I'd say low brake pads or possibly a bent dust shield if a wheel was off recently.
Old Aug 20, 2012 | 12:32 PM
if it gets worn all the way, it would be there all the time!
lol ask me how i know.
Old Aug 20, 2012 | 01:26 PM
ez12a's Avatar
the overexplainer
Yep, if the brake pads are worn enough, the indicators will grind w/ the rotor regardless whether or not you're braking. My sister's civic did the same thing.
Old Aug 20, 2012 | 05:04 PM
Renescent's Avatar
Need new brake pads... and don't drive with the scraping for long or you'll need new rotors too :P:
Old Aug 23, 2012 | 09:25 PM
LoveMyTL-S's Avatar
Check brake dust shield. This was bent on my son's TL-S. Or brake pad was installed backward. But I'd go with the bent brake dust shield.
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
kixo
Sep 25, 2015 03:07 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
