Loud rattling and poor power steering when cold
Old Dec 12, 2013 | 05:31 AM
djdonte's Avatar
Here in Houston its in the 30s and 40s in the morning and my car has started making some noises. There is alot of noise coming from the accessory side of the engine on cold start up only in the morning. The steering wheel is hard to turn and i hear the belt squeal when I turn it. The sound at idle is not squealing like a slipping belt but a rattling noise. By the time I got to work my car was warmed up and of course it stopped.
I am not sure if my car is affected by the P/S o ring recall thing or not. I was thinking of just replacing the belt and if that doesn't help, replacing the tensioner. I am still under my powertrain CPO warranty. Do you think these problems would be covered? I did a search and found one guy who said he replaced his tensioner and it helped.... but I was hoping one of you guys have a definitive answer or similar situation before I start changing parts. Thanks.
Old Dec 12, 2013 | 05:33 AM
paperboy42190's Avatar
have you rebuilt the power steering pump yet? if you've got at least 80k miles its about time
Old Dec 12, 2013 | 05:39 AM
djdonte's Avatar
I have about 78K on it. I did not see that item in the maintenance schedule.
Old Dec 12, 2013 | 06:15 AM
djdonte's Avatar
I am going to call my guy at the dealership and see what items are covered on the CPO powertrain warranty.
Old Dec 13, 2013 | 05:01 AM
djdonte's Avatar
Well upon closer inspection it was coming from the power steering pump... I replaced the return hose o-ring with the DIY on this forum. Fixed the problem with a 77 cent o ring from the dealer! Acurazine FTW!
Old Dec 13, 2013 | 05:52 AM
like I said before, the power steering pump will go soon. the O ring you did is the most common one and makes noise first, however soon you will see fluid seeking from the bottom of the pump. its pretty much a guarantee once you hit about 100k miles.
since yours may or may not be leaking yet, just keep a close eye on it, sometimes its not easily apparent unless you look for it.
Old Dec 16, 2013 | 11:00 AM
djdonte's Avatar
I checked and its definitely not leaking. Ill think about rebuilding it when it leaks or when its time for my 105K mile service, whatever comes first.
Old Dec 16, 2013 | 09:47 PM
flint's Avatar
There have been a few failures but I don't think it is a guarantee his pump is going to fail. Many are fine well beyond 100k miles.
Old Dec 16, 2013 | 11:02 PM
LaCostaRacer's Avatar
From reading the title of this thread it sure seemed like the o-ring issue. It's nice hear it was a simple/cheap fix.
Old Dec 17, 2013 | 07:16 AM
djdonte's Avatar
Lol I would hope it doesn't leak. The P/S pump on my beat up hyundai with 200K on it doesn't leak or make noise. All the hoses and fittings are weeping/leaking but the pump is still solid!
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
