2004 Acura TL Subwoofer
Old Feb 19, 2010 | 08:27 AM
cdp5095's Avatar
04 tl
can someone please tell me how to get to my sub in my 04 tl.. i kno i have to take the back carpet in the trunk,but i just dont want to break anything. reason i want to get to it, is becuase it sounds like its blown, it rattles to much. appreciate any help guys thanks.
Old Feb 19, 2010 | 08:35 AM
blkaspec's Avatar
Full of water...
does the sub rattle, or does your rear deck rattle which is caused by the sub? this is a known issue and can easily be fixed with some felt. I think others have had their rear seat belts rattle too, but the majority suffer from the deck rattle including myself. just something to think about before you start tearing things apart.
Old Feb 19, 2010 | 08:40 AM
cdp5095's Avatar
04 tl
yea i heard about that, but im pretty sure that its the sub, becuase i put my hand down near the deck to put presure to see if it was the deck but no the rattles goes alil bit away but it still is there... and when my radio is even at bout 4 or 5 % it still rattles so im pretty sure its the sub.
Old Feb 19, 2010 | 12:31 PM
caseysacura's Avatar
mine is doing the same thing. rattles when i turn it to like volume 10 but then when i turn it up and let it hit hard it ends up fading a little bit. tried the hook thing under the light in the trunk but it doesnt sound like the sound is coming from there. not sure how to get to the sub either
Old Mar 2, 2010 | 10:42 AM
dhughes12's Avatar
mine does the same thing, the sub is blown. i've tried to find them online, but all i've found is subs for a 01-03. anyone know where i can get one?
Old Mar 2, 2010 | 12:11 PM
DonnieDarko8221's Avatar
I just had mine replaced by a Honda dealer. You need to take out the back seat and take apart the rear deck to be able to removie the sub. The service guy told me it was a pain in the ass. The part number for the subwoofer is 39120-SEP-A22 (speaker assy. 20cm) acuraoemparts.com has it listed for $52.30. It also says it is for model years 2004-2006.
My sub was making a popping sound so I knew it was blown. I opted to just replace the stock sub instead of going aftermarket because I didn't want to lose any truck space and the stock sub is ok enough for me. I don't need a heavy hitting system.
Old Jul 20, 2013 | 09:21 AM
Walfredo's Avatar
4th Gear
I just bought an '04 A-spec about a month ago, and my stereo has been finagled with prior to my ownership... There's an 800 watt Sony amp in the trunk that's wired into the stereo, with a wire run out for a sub... But the previous owner apparently took his sub when he traded it in. And the factory sub is either not working or unhooked due to his previous sub. So I have no bottom end to the ELS stereo in my sweet ass A-spec... It's got navi in it so I'm kinda scared to fuk with the stereo and what not. Suppose I could just hook a sub up in the trunk near that big ass amp the dude left in the trunk. Any suggestions would be appreciated. Thanks
Old Jul 20, 2013 | 10:14 AM
abirvalg's Avatar
nice revive! well, at least you've searched
you have to figure out how the aftermarket amp is wired before deciding on the course of action
look behind the pass seat kick panel cover, that's where the stock amp is(was) located
it should give you some clues as to what channels where used
you'll have to reverse engineer the setup
Old Jul 21, 2013 | 06:21 PM
Vlad_Type_S's Avatar
Registered Bike Offender
The first thing I would check is the factory sub connector and the factor amp connectors. See what's going on over there and see where those wires are running to. That should give you a pretty good idea of what's going on so that you can get back to an OEM setup.
Old Dec 17, 2013 | 09:15 AM
DBConz's Avatar
Registered Idiot
sorry to bump, but i'm experiencing a rattling too. the plastic child seat clip has felt, the passenger seatbelt was already replaced. my 06 TL is now out of warranty. what else can i check? it's only on certain songs (frequencies).
are you guys putting a 9v battery to the sub to test if it's blown?
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
jamestheunderdog
Jul 19, 2016 07:58 PM
sockr1
Oct 1, 2015 01:31 AM
Gianni Formica
Sep 7, 2015 08:28 PM
