Loud chirping noise is finally gone!!!!!
Old Jun 24, 2010 | 07:44 AM
cutzmansi's Avatar
I know a lot of people have been having an issue with a loud chirping noise coming from the drive belt side of the motor. For 6 months I kept gettiong the run around saying it's the fan belt ect. Finally I went to another dealer in jersey (turnersville acura) and the tech knew exactly what the sound was and had a fix for it in about 15min, it was just a simple heat shield... wow I never knew it could cause so much headache. thank god it's gone!!!!!
Old Jun 29, 2010 | 01:48 PM
RjG2's Avatar
Did it sound like it was your belt before you got the problem fixed.
Old Jul 2, 2010 | 10:46 AM
AMlove's Avatar
7th Gear
i'll have to check this out. i have a chirping noise too. what heat shield specifically is this?
Old May 2, 2012 | 10:41 PM
FC3S Murray's Avatar
Need pics of which heat shield
Old May 2, 2012 | 11:03 PM
Will Y.'s Avatar
Registered but harmless
Intermediate drive shaft heat shield; for link to the TSB containing a diagram (IIRC), see post #7 of this thread: https://acurazine.com/forums/3g-tl-problems-fixes-114/rattling-drive-shaft-heat-shield-839129/.
Welcome to AZ.
Old May 3, 2012 | 05:37 AM
Turbonut's Avatar
Easiest way to test, remove the serpentine belt and start the car, no noise in belt area you've found the location, but if noise is still present you'll know where not to look.
Old May 3, 2012 | 06:27 AM
tihomirbg's Avatar
What did the tech do to that shield? Changed it?
I did the 2 pulleys and the drive belt and still have that chirp sound in the morning
Old May 3, 2012 | 09:15 AM
flyromeo3's Avatar
perhaps my thread doesnt show up in search results?
https://acurazine.com/forums/3g-tl-problems-fixes-114/fighting-squealing-noise-778285/
Old May 3, 2012 | 09:20 AM
flyromeo3's Avatar
This was my initial troubleshooting procedure.
Followed by placing a flat head screw driver against the shield and applying pressure to see if it quiets the noise down.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
