License plate LEDs connector issue
Old 08-29-2013, 03:22 PM
4th Gear
Inliten's Avatar
Hey guys, apologies in advance if this has already been addressed in a previous thread, but I did a search and couldn't find anything similar.
I purchased some LED license plate lights on Amazon (
iJDMTOY Super Bright 18-SMD OEM Replacement LED License Plate Light Lamps For Acura MDX RL TL TSX ILX Honda Civic Accord Odyssey, etc : Amazon.com : Automotive iJDMTOY Super Bright 18-SMD OEM Replacement LED License Plate Light Lamps For Acura MDX RL TL TSX ILX Honda Civic Accord Odyssey, etc : Amazon.com : Automotive
) and tried replacing. The description states that it is a valid plug-and-play replacment for the 3rd gen TLs, among numerous other models. Naturally, the connectors don't match. The OEM connector on my 2008 TL has never been changed. It's a square end with four holes, vs the T10 with only the two connections. I e-mailed the seller and they claim that a T10 socket is stock on the '08 TL, but clearly not seeing as the socket in question has never been replaced since the vehicle was purchased new.
Anyone else run into this and have a resolution? Is there some kind of connector you can use to make it work, or would splicing be a better option? Any help is appreciated!
Old 08-29-2013, 03:28 PM
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
the TL's license plate lights ARE the type with just the 2 connector male ends.
idk what you have. pics?
Old 08-29-2013, 03:45 PM
4th Gear
Inliten's Avatar
Thanks for the reply. Here's a link to a couple pics of the one that's on the vehicle now:
http://i992.photobucket.com/albums/a...psad87cd4b.jpg
http://i992.photobucket.com/albums/a...psf6175b59.jpg
Old 08-29-2013, 03:47 PM
BANNED
oh.
that's totally normal.
that's just the harness connector. you need to physically remove the bulb itself from the little housing it is in. replace bulb. plug in and fire it up.
The following 2 users liked this post by SharksBreath:
ggesq (08-30-2013), Inliten (08-29-2013)
Old 08-29-2013, 04:09 PM
4th Gear
Inliten's Avatar
I figured it would be something simple, thank you so much for your help!
Old 08-29-2013, 08:14 PM
zubi23's Avatar
I actually need to get some license plate LED lights, is it just a plug and play? What's the number of the lights that I should look up? Blue or White?
Old 08-29-2013, 09:36 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
^white for sure. blue for license plate lighting is too tacky IMO, white is nice and clean
btw to the OP, almost all honda/acura license plate housings are identical, you dont even need to remove the plug(the one in your pic), just pop off the housing from the clips, simple as that
Old 08-29-2013, 10:24 PM
Gil'sUA5's Avatar
Yes they are plug and play though it does take a little longer than other cars to install them probably like 15 minutes for a first timer. They are 194 bulbs and are very easy to find online, a bunch of different places you can get them.
Old 09-04-2013, 08:11 PM
zubi23's Avatar
anyone have a DIY on this.
I'm thinking of getting these:
http://www.ebay.com/itm/2-X-BACKUP-REVERSE-Xenon-White-Wedge-T10-30-SMD-LED-Light-bulbs-921-194-W5W-2825-/261275833105?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cd540d311&vxp=mtr
Old 09-06-2013, 10:38 AM
Received 8,611 Likes on 6,650 Posts
Search in the Garage. It's in there.
2 x Backup Reverse Xenon White Wedge T10 30 SMD LED Light Bulbs 921 194 W5W 2825 | eBay
cycdaniel
12-17-2019 10:58 AM
HOWELLiNC
3G TL Photograph Gallery
24
10-08-2015 03:15 PM
lland
10-04-2015 04:47 PM
darksky
09-05-2015 03:11 AM
Quick Reply: License plate LEDs connector issue
