Leaked green fluid when backed out of snowdrift
2006 manual transmission. 152K miles
Hi all. I have been racking my brain trying to understand what this fluid is. I know most of you are going to say coolant, but please read my diagnosis. A few weeks ago, my car got snowed in and I had to dig it out. In this process, I had to put the car under a bit more stress than normal. Nothing crazy, I kept the traction control on and just rocked it back and forth for a while until it came free. When I left my parking spot, I noticed a spots of green fluid down the middle of the parking spot. I thought immediately, coolant and checked my temperature gauge and it was fine plus I had the right amount in my coolant reservoir, between min and max. I let it run for a few minutes to see if I could generate the leak again and could not. I put down some white paper under the car under the engine bay and rev'ed it to 4,000 rpm and I could not generate any leaking. I thought maybe it's clutch fluid, I depressed the clutch several times, no problems. Granted, the car was not in gear when I did my test. I have been driving it 2 weeks later and no problems. There's a lot of snow where I live and I have not seen any more fluid leak while sitting idle in the snow.
The coolant in the system is from the factory since I have never done a coolant flush (maybe overdue), but when I open the reservoir tank, it's a dark blue fluid, almost like windshield washer fluid but much darker. Yes, I am sure this is my reservoir and not the washer fluid tank
Was I really leaking coolant or could this be something else?
. Was I really leaking coolant or could this be something else?
Well it wouldn't be coolant, because as you saw its blue. That is the Honda/Acura factory color, so don't be troubled. Not real sure what the green fluid could be... was there a lot of it? For sure though, its time to change the timing belt and water pump... 152k is dancing with the devil.
That had me thinking! Don't those A/C leak type things also come in florescent green to detect leaks in your air conditioning. If not the oil, have you had any issues with your refrigerant / A/C system leaking? Maybe that undue stress on your car caused a small leak in the system?
) come colored... and often in neon green. Maybe his A/C system was previously patched by someone, may it be him or a previous owner.
cycdaniel
Dec 17, 2019 10:58 AM
nanos
Nov 12, 2015 08:41 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
HeloDown
Sep 8, 2015 06:51 PM
