Keyfob probs...
Old Feb 24, 2015 | 11:49 AM
sara21tks's Avatar
Keyfob probs...
So I posted about this a while ago and since then havent really been able to find anything out... I have the 2 keys that the car orig came with but when I use #1 it messes with all my radio presets and my a/c and heater settings. Also, sometimes it doesnt work at all to unlock/lock the doors as well as wont pop open the trunk. It doesnt do it all the time, just sometimes. When I use #2, it works perfectly fine. Any ideas what could be causing this problem?
Old Feb 24, 2015 | 11:51 AM
Check out the 3G Garage/ Service Department for all of your problems in the future. Chances are they have been reviewed and answered:
https://acurazine.com/forums/third-g...-079-a-556315/
Old Feb 24, 2015 | 11:53 AM
sara21tks's Avatar
Thanks!
Old Feb 24, 2015 | 01:11 PM
guitarplayer16's Avatar
Try replacing the battery in the keyfob, that should fix it.
When you use keyfob 1, it is linked to its radio presets and heater settings
Same with keyfob 2, it has its own settings.
Your options are easy.
Either stick with one key, or set up the same radio presets for keyfob 1.
Old Feb 24, 2015 | 02:29 PM
06TLMatt's Avatar
You can also get a new ( not OEM ) key fob off of ebay for 24.95 Shipped ( also comes with a transponder key . I did that and it works great, just doesn't have the memory settings like the OEM ones do. I assume the key works but I went to ACE to get them to program it for free and they bent the key while cutting it, so I'm not sure about that
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
Phillyboi
Sep 20, 2010 11:27 PM
Sniper3.0
Jun 5, 2008 10:38 PM
RL_Cruizin
Sep 28, 2005 01:29 PM
badboy
Aug 2, 2005 11:49 AM
