Key won't turn/steering wheel is locked
2006 6spd
I would think it would have to be that the wheel maybe locked tight to one direction our maybe you're parked on a slant I'm sure the wheel needs to be turned to get the key in?...
2004 Acura TL
https://acurazine.com/forums/3g-tl-problems-fixes-114/help-steering-wheel-locked-796552/
Read Justins post and keep trying! Happened to me last time, it usually happens when you park your car and turn off the engine with your steering wheel turn a lot
the overexplainer
yeah usually this is caused by the steering wheel "sitting" on the locking mechanism. I usually just turn the wheel a bit so it's not resting on the steering wheel lock and then the ignition turns.
make sure your shifter is in Park also.
but this doesnt explain why your key doesnt go all the way into the ignition.
HE SAID he cant even get the key to go ALL the way into the ignition!. Which means a tumbler proly fell in the lock cylinder. Which means you need a new lock cylinder. sorry buddy. but those are not really easy to take apart and occasionally have "break away" bolts. so if your not very mechanically inclined i would bring it to a shop. rocking the car or turning the wheel will not help
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
ahsm
09-09-2015 08:35 AM
braveheart
09-07-2015 08:12 AM
