Key will not turn after ignition switch replacement.
Yesterday I went to start my 04 tl and when I turned the key it made a buzzing noise under the steering wheel. It took about 4-5 tries before the car finally turned over. Leaving work was the same issue.
I recently replaced the starter and battery so I know that's not the issue. I get the new ignition switch and installed it this morning. I disconnected the battery before install, Once I reconnected everything and tried to turn it over the key would not move into the on position. It won't budge and I've tried wiggling the steering wheel as well and still nothing.
you will have to "shimmy" (for lack of a better word) the steering wheel with the key in the ignition and turned to the "II" slot.
Also, move your gear shifter a bit, sometimes it is in between gears and the car won't turn over as a result.
I've shimmied it like it's a drunk Friday night! It wasn't locked at first, until I tried moving the steering wheel also tried moving the gears by placing the key into the little hole on the shifter and still no luck. Could it be anything else?
Sometimes when I try to start my car I hear a buzzing noise from the ignition area before it starts just like this. She says its the electrical ignition starter switch. Part #:
Part Number 35130-SAA-J51
Genuine Acura Ignition Switch - Acura Parts Warehouse
This is the install video, probably similar install to a 2005 TL?
so i didn’t exact same thing and turns out you have to take the key cylinder and release the rod that attaches to the key switch. I realize this response is old , but this video shows how to take it out and apart without having to replace anything.
Just replaced my ignition switch. No buzzing and key didn't lock.
I got it of Amazon for $40. It was a OEM Honda for half the price than on Acura dealer website.
https://www.amazon.com/Genuine-Honda-35130-SAA-J51-Steering-Switch/dp/B00BFDGSSY
.I got it of Amazon for $40. It was a OEM Honda for half the price than on Acura dealer website.
thx1138
Sep 3, 2023 08:58 AM
typicalintrovert
Feb 6, 2021 07:04 PM
