Intermediate shaft tick
Old Aug 21, 2019 | 10:22 PM
04Tala's Avatar
7th Gear
So I have 04 TL 6Speed and the problem I'm having is that it shakes under acceleration only. If you're under the car you can hear a small tick from the intermediate shaft. What could it be ? Both wheels look like there moving up and down while rotation and I've put new tires and balanced them. Anyone experience the same thing.?
Old Aug 21, 2019 | 10:26 PM
ttribe's Avatar
MODERATOR NOTE: Thread moved to model specific forum.
Old Aug 21, 2019 | 10:56 PM
csmeance's Avatar
Shaking under acceleration usually is axles, esp if the car is lowered. Intermediate shaft can be an issue if the worn axle is left on for too long and wrecks the bearing on the intermediate shaft. I'd recommend replacing all 3 and also checking the trans upper and lower mounts and also your engine mounts. Rubber ages terribly and they are probably cracked/torn.
Old Aug 21, 2019 | 11:00 PM
04Tala's Avatar
7th Gear
I've replaced the front mount and side transmission mission mount. Motor and transmission are solid under a load. Axels aren't clicking, nor are the boots torn. But it seams like there's a slight tick by the intermediate shaft.
Old Sep 18, 2019 | 03:25 AM
Bulio's Avatar
Talking
I had a similar situation with my Intermediate Shaft and it turned out to be that the support bracket that connects the bearing enclosure to the engine broke. My recommendation would be to inspect and/or repair it immediately before it snowballs into a much more costly repair or accident in the future. I replaced mine by myself in less than 90 min and saved a lot of $$$. Hope you get it figured out, Good Luck!
jbc3
Oct 17, 2015 12:55 AM
samplemonster
Apr 16, 2013 11:36 PM
stayclassy
Jan 22, 2012 03:14 PM
MMazzio
1G TSX Problems & Fixes
Aug 1, 2010 06:25 PM
JBlueCLS6
Jul 24, 2007 02:16 AM
