How many have Auto Window Rollup Problem?
Old Mar 14, 2011 | 07:32 PM
IDM's Avatar
IDM
My drivers side window comes back down when I use the auto roll up feature.
How many of you have this problem? Just wondering how common it is in TLs as I've seen it in other cars.
Is there a way to quickly recalibrate the motion of the window or is a part needed?
Old Mar 14, 2011 | 08:10 PM
Timb227's Avatar
Fear and Loathing in my
Not sure about others, but I have it happen sometimes to my driver side. Curious to find out what may be causing it.
Old Mar 14, 2011 | 09:25 PM
guitarplayer16's Avatar
This happens to my passenger side.
I just let it be =(
Old Mar 14, 2011 | 09:33 PM
nfnsquared's Avatar
Search. Many threads on this...
Old Mar 14, 2011 | 09:58 PM
IDM's Avatar
IDM
its the only thing wrong with my car which is near mint, so Im curious how many others had it happen and what years.
IDM's Avatar
IDM
yes many useless posts on the forum, but that didnt seem to stop you either
I think we better stop we might fill up their database
Old Mar 14, 2011 | 10:14 PM
navarretg's Avatar
2004 Acura TL
I kinda noticed that too sometimes. I thought it was my mistake but I second questioned it but I didn't think much about it? It doesnt happen often though.
Old Mar 14, 2011 | 10:18 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
It happens often. It's a fuse issue. But, you can self-reset the window switch.
1. Roll window down by keeping your finger fully depressed on the switch. Keep your finger fully depressed on the switch for 2 full seconds after the window is completely down.
2. Repeat above when rolling the window up. Hold window switch in the fully-up position for 2-seconds after it's fully closed.
Problem should be solved. However, it will return periodically.
Just continue to repeat the above steps when this happens.
Old Mar 14, 2011 | 10:37 PM
IDM's Avatar
IDM
Thanks I will give that a try, its the only thing left thats wrong with my car so now that Ive fixed the rest its starting to become obvious. Mine happens half the time I use the window.
Thanks again!
Old Mar 14, 2011 | 10:50 PM
nfnsquared's Avatar
OP, had you taken the time to type "window auto" in the search bar instead of starting another thread, here's the threads you would have found in the top 10 results:
https://acurazine.com/forums/showthr...ht=window+auto
Old Mar 15, 2011 | 07:59 AM
IDM's Avatar
IDM
thanks and if you had just put the links and not bitched for two posts it would have been great too. I guess nobody is perfect. Also making a new thread brings this to other peoples attention who may not have thought it was a problem on their car and now see the simple fix which has already been posted above
Old Mar 15, 2011 | 12:37 PM
user 0579729724's Avatar
09 Accord Coupe 6 Speed
My brand new TL came off the lot with this problem when I bought it in 05. I never bothered to take it into the dealer until last month (out of warranty). It was the window regulator. Cost me about $250. to get replaced.
Old Mar 15, 2011 | 02:42 PM
nate_0022's Avatar
Land of 10,000 lakes
My drivers side does this a lot, I'll have to try the reset method, my passenger side does it but rarely, but my main concern would be my sunroof, when I crack the sun roof in the up position and I want to close it, it will close but pop back open right away, try to slide it open it does the same thing.
I'll search through the threads nfnsquared posted, just wanted to see if anyone if having the issues with the sunroof.
Old Mar 15, 2011 | 02:58 PM
Try the same method with the moonroof switch.
Old Mar 15, 2011 | 03:07 PM
IDM's Avatar
IDM
Search man there have been so MANY threads on moonroofs! Just kidding Im not Annoying
Old Mar 15, 2011 | 06:14 PM
Schulminator's Avatar
it's 4:20
Just like OP I could not find anything in the search engine, as I did search "auto window". I do thank you for posting the links, as I just fixed my D/S window that would not close in Auto mode....Thanks again!!!!!!!!
Old Mar 15, 2011 | 06:29 PM
nfnsquared's Avatar
Huh? There's like at least 10 threads on the first page of the search results:
https://acurazine.com/forums/search....archid=5119405
Old Mar 15, 2011 | 06:58 PM
IDM's Avatar
IDM
I just tried this and basically it broke the window. I had to turn the key on and off a bunch of times and play with it to get my window back up. It made it 100 times worse now it has a hard time going back up at all and gets stuck at the bottom until I play with it. Any ideas guys!?
IDM's Avatar
IDM
Yur the man
Old Mar 16, 2011 | 08:14 AM
it's 4:20
With your replies, you're actually a bit of a ****.......
Old Mar 16, 2011 | 12:54 PM
IDM's Avatar
IDM
Any suggestions here?
My window regulator seems to be overheating is that possible?
If I let it be for a while the window goes up and down but yestrday when I was messing with it it wouldnt go back up for a few minutes after this two second technique.
It scared the crap out of me I had never had that problem before just that on auto rollup it goes back down sometimes.
Old Mar 16, 2011 | 01:38 PM
nfnsquared's Avatar
If the reset procedure didn't work, then I'd guess it's a bad regulator. They've been known to go bad at what I consider to be a higher than acceptable rate (and that's just based on what I've seen on Azine, not the entire TL population).
Old Mar 16, 2011 | 03:34 PM
skibum's Avatar
I just went in for an oil change yesterday and was getting it where I went to put up the passenger side window and it would stop half way up and go down. They came back 30 min. later and said both front windows had regulator and channel problems and replaced both for me for free under acura care warranty. Otherwise would have been a $800 repair based on my receipt.
Old Mar 16, 2011 | 04:02 PM
IDM's Avatar
IDM
How do I get it resolved if it is a fuse issue? Can I swap a fuse now since they are so easy and cheap?
Old Mar 17, 2011 | 01:19 AM
Disbe's Avatar
Im pretty sure its not a fuse issue. I would be willing to bet your windows are tinted. The tint is causing too much pressure in the window jam and is causing the window to think something is stuck in the track. Roll it down, put some grease in the track, do the window reset and you are good. As others have said there are tons of threads on the matter. Instead of calling people jerks for not just telling you what to do, try searching more, or ask maybe ask for help on how to search. It does get old seeing the saaaaaame stuff constantly reposted. Theres no need to start a new thread so others can see the issue as the older threads constantly get bumped to the top.
If you dont have tinted windows i have no idea what the problem could be.
Also, even if its factory tint, Acura will not stand behind the issue.
Old Mar 17, 2011 | 09:27 AM
IDM's Avatar
IDM
I do have tinted windows 15% all around.
I got the car tinted the week after I bought it so I can't say if it was doing it before the tint.
Is there a way to grease the track without taking the door panel off?
I wonder why my passenger window goes up no problem with auto rollup?
Old Mar 18, 2011 | 11:24 AM
jr27's Avatar
2005 AM at/navi
i had this same problem with my passanger window, half way up and it would go back down. i just go up manually and forget a bout it, then next time it is gone. it doesnt happen too often, i thought i was the only one and that my window motor was going out. good to know it is pretty common i guess.
Old May 9, 2011 | 06:26 PM
gogators22's Avatar
I tried this, and it made it 100x worse. The window won't roll up more than 60% after I roll it down the FIRST time. Each time I rolled it down after, it went up less and less, until I had to pull it out of the door with my hands
FML this sucks. I finally got it all the way up and just put window lock on, so at least I'm the only one in control of accidentally rolling it down.
Old May 9, 2011 | 09:41 PM
IDM's Avatar
IDM
Try letting it cool down the same happened to mine.
Don't try the fix again just leave it and it should go back to how it was
Old May 10, 2011 | 01:27 PM
myblack04tl's Avatar
Mine had similar issues, I replaced the window regulator myself and it fixed it. $85 for the part.
Old May 13, 2011 | 01:18 AM
ganjaghost72's Avatar
lol i love how some windows got worse, happens to passenger side mine but i noticed it starting to happen after i left the window in a car wash a bit open
Zonian22
Nov 14, 2015 01:20 PM
mazen222
Oct 27, 2015 12:01 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
ahsm
Sep 9, 2015 08:35 AM
asahrts
Sep 4, 2015 05:55 PM
