Hole in subframe in control arm area. Weld? Replace?
Old Aug 9, 2023 | 06:44 AM
robster80's Avatar
Somehow this happened. Can this be properly welded? Or am i gonna need to replace the subframe? Ive asked around some and have gotten different opinions but most say replace. Was just curious if anyone else had this issue and what was your fix? Getting frustrating. Ive had engine Tore down gettinf re-sealed and all sorts of other issues i keep finding. Steering rack needs replacing, need new ps pump, rear panel needs repainting, needs valve adjustment, timing belt past due. Now this.
Old Aug 9, 2023 | 01:00 PM
Is that the upper control arm area or lower?
Old Aug 9, 2023 | 03:35 PM
robster80's Avatar
lower
Old Aug 9, 2023 | 04:06 PM
Looks like the guy below had a similar problem and replaced the subframe.
Click the blue arrow next to his name & it will take you to the thread.
Originally Posted by TacoTom1967
Passenger side.
Update: We’ll, I’m glad I’m doing the subframe swap too. The steel lower control arms had eaten the aluminum mount on the subframe almost in a complete circle on the bottom side on the passenger side of the car and was just starting to break through on the drivers side. Obviously, if the bushing in the front mounting point of your front lower controls is failing or has failed, I suggest you replace it ASAP.
Old Aug 9, 2023 | 06:49 PM
El_Cheapo's Avatar
Sounds like you're looking for the answer you want to hear so just JB Weld it and call it good. 🤷
Old Aug 10, 2023 | 12:52 PM
robster80's Avatar
no i want to hear what is best to do so if i can find a subframe at a good price and someone to install ill go that route
Old Aug 10, 2023 | 01:21 PM
Not sure if you are manual or automatic, the part #'s are different.
Make sure to search the correct part # for your TL.
Cheapest automatic one on ebay:
Crossmember/K-Frame Front Automatic Transmission Fits 2007-2008 Acura TL OEM | eBay
Otherwise, you may be able to beat that price by finding one locally on car-part.com salvage website.
Use 'Engine Cradle' in 'Select Part' field.
Good Luck!
Old Aug 12, 2023 | 03:52 PM
robster80's Avatar
Subframe question
Are the auto 04-08 aubframes the same? Im being told they are, then some say no the 04-06 are different, then someone sent me a link and every year the part numbers are different even the 07 and 08 are different part numbers. Does anyone know for sure? Mines an 07 Type S AUTO
Old Aug 12, 2023 | 04:41 PM
What did your online OEM vendor research results (like the one below) indicate to you for the specific automatic model years above?
Genuine OEM Acura Parts and Accessories Online - Acura Parts Warehouse
Old Aug 12, 2023 | 06:47 PM
robster80's Avatar
that is what im saying the 07 and 08 are two different part numbers according to your link the 08 wont fit. Im being told it would work anyway but wanted to know for sure
Old Aug 12, 2023 | 11:06 PM
Looking at your picture, it appears this damage shown below is either on the left or right side of the subframe circled in green on the diagrams below the picture.
Comparing & contrasting the 07 / 08 OEM vendor parts diagrams below & assuming they are accurate,
your 07 TL-S Auto has 'differences' between the 08 TL-S Auto marked in red.
07TL-S:
08 TL-S:
Even if you wanted to purchase for big $$$ a new Auto 07TL-S subframe, they appear to be discontinued.
Therefore, if you get one (07) second hand you need to make sure to verify if the little two hole platform (next to #1) are present to make the connection for whatever goes there versus the 08 subframe that does not have one.
Same applies to the two red arrow items in front of the the area circled in green.
They are different between the two years, though, I suppose you could get an 08 to work on your 07 if the differences are not a concern to you?
These noted subtle differences, if they are depicted accurately on the diagrams, are the reason why the subframes have different part #'s, cabeesh?
Old Aug 13, 2023 | 04:24 AM
El_Cheapo's Avatar
Interesting. I assumed all the 07-08 autos had the same subframe.
Old Aug 13, 2023 | 06:58 AM
On a positive note for the OP, on APW's website there is an indication that the 50200-SEP-A05, from the 08, can be used because of A04's discontinued status:
Furthermore, going back and reexamining the one on the ebay link I provided in post #7, when I specifically googled 5200-SEP-A04 that is one example that came up.
With that said, If that one is to be considered for purchase, because, at best you, want an 07 specifically, I would compel the seller to first send pictures of the other side of the subframe listed.
The picture shows only the side that faces the road when mounted to the engine / car.
Here's is another below listed as 5200-SEP-A04; however, if the OEM vendor diagrams I used above are accurate, it clearly looks like an 08 subframe?
2007 07 ACURA TL TYPE-S - FRONT SUBFRAME CROSSMEMBER K FRAME - AUTOMATIC OEM 87 | eBay
This is why it is very important to perform your 'due diligence & know your sh!t' when you are forced to purchased 'used' expensive parts because the OEM one is discontinued.
Having an 03 CL-S six speed, I am all to aware of having a car where a lot of parts on it fall under the 'discontinued' category. Every time I need a critical part and it is discontinued, this is the dance I go through to make sure I get as close as possible to what I need to maximize fitment.
Old Aug 13, 2023 | 02:23 PM
robster80's Avatar
appreciate that info! Not sure what ima do. Got so much maintenance to do on this thing im tempted to sell aa is ans get it outa my carport or maybe just weld it and send it
Old Oct 3, 2023 | 11:53 PM
Bense's Avatar
$75 for subframe / "k-member" from my local pick 'n pull. @zeta is correct. All 3g subframe are same except 07-08 AT. They've got that funky bracket. It can be chopped off if you're using an 07-08 TL AT subframe in a 03-07 Accord, 04-06 TL, or a 07-08 TL 6MT.
Its about 42 lbs. Recycle your old one and net about $10 more than the junkyard core charge
max parker
4G TL Problems & Fixes
Apr 20, 2023 08:44 PM
noellandas
Jan 29, 2021 11:38 AM
Joneill44
Oct 21, 2012 01:08 AM
