HELP!!! TL-S Aspec spoiler help!
Old Oct 27, 2008 | 01:09 AM
ballerjai's Avatar
Make Nice, Not Rice
I'll keep this brief with as much details I can give.
I installed my Type-S Underbody spoiler on Saturday(10/25). Everything is great, except the front bumper. I did a search, so please don't own me with "search newb." Anyways, I guess no one had this problem.
There seems to be a gap between my oem front bumper and the A-spec. I'll show pictures since it's hard to explain.
Pressing on the bumper.
Can you guys see the gap?
What should I do? I bought double side tape.. should I apply it? I went through the instructions 3 times. It seems like the only thing holding the kit in that upper area is another strip of double sided tape. I doubt I missed any screws.
Old Oct 27, 2008 | 03:04 AM
ballerjai's Avatar
Make Nice, Not Rice
Can someone please help me?
Old Oct 27, 2008 | 03:10 AM
TheWanderer316's Avatar
'10 Shelby
i would definitely put the double sided tape on. The stock tape they have on there isnt strong enough.
Old Oct 27, 2008 | 09:50 PM
jnnyjuice's Avatar
did u do all the proper drilling?
i had the same problem with mine. i shifted the kit a bit and secured it with a little extrade double sided tape, should do the trick
Old Oct 28, 2008 | 06:05 AM
ballerjai's Avatar
Make Nice, Not Rice
holes were drilled flawlessly, I used more double side tape and it solved the problem. Thanks! Mod please close.
Old Oct 29, 2008 | 01:31 AM
ballerjai's Avatar
Make Nice, Not Rice
Crap, it came loose again even with the double sided tape. When you applied it, was it set after that?
Do you think the cold weather has anything to do with the tape not sticking as well?
Old Oct 29, 2008 | 08:52 AM
csmeance's Avatar
did you clean the area with isypropl (sp?) alcohol? if not, its just sticking to dirt. Also if you use a second person, heat the bumper up with a hair-drier and then slowly put the kit on a section at a time.
Old Oct 29, 2008 | 04:17 PM
ballerjai's Avatar
Make Nice, Not Rice
No alcohol was applied, I did wash the car prior before installing. I think that was a bad idea now considering, it made the car slippery (wax like feeling). Isypropyl alcohol is basically rubbing alcohol right? That can simply be bought over the counter from a store like safeway/walgreens correct?
Heating the bumper makes a lot of sense, I'll do that next when I get home this weekend. Also at Kragens(Auto store), they offered two types of 3M double sided tape. I don't recall the exact measurements, but one was thicker than the other, I went with the thicker tape. Now, I'm kind of regretting it because the tape is so thick the bumper is sticking out. To be more detailed to where I stuck the double sided tape, I placed it right over the OEM stickers.
Do you guys have any recommendations or tapes you have used? I appreciate all the help guys!
Old Nov 1, 2008 | 11:33 AM
bmwproboi05's Avatar
iono what kind of tape u using? i have the semi thick double sided tape. its like as thick as ur headphone wires. if you think that would help i can see if i can find something to cover it an send it to you? I have a hole roll of it xD
Old Nov 7, 2008 | 02:08 PM
omarb420's Avatar
hey you installed it yourself? did you even jack up your car?? how much did you get it for? im thinking of getting one but my car is dropped pretty low so if i put that its gonna be like a inch or more away from the ground,......
Old Nov 7, 2008 | 10:23 PM
flip_side's Avatar
now that this whole double sided tape issue has been brought up.. I have some super strength molding tape by 3M from autozone is that good? or is there another tape I should be buying.. hope this helps more people out too
08KBP_VA
Oct 22, 2019 01:55 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
rhdune16
Sep 28, 2015 11:31 AM
spoiler900
Sep 23, 2015 04:41 PM
