Help Needed! 04 TL ignition issue?
Old Jun 3, 2019 | 07:18 AM
DejaVu85's Avatar
śïιέит вµт đέαđιý
Volume up - Anyone know what part I need to replace?
I thought it was the starter and replaced that but that didn’t fix this issue.
Old Jun 3, 2019 | 07:41 AM
6speed?
Old Jun 3, 2019 | 07:59 AM
Jackass's Avatar
Negative...look at that big pedal hiding down there.
Old Jun 3, 2019 | 08:41 AM
sounded like the flywheel smacking/grinding against the starter drive pinion gear
Old Jun 3, 2019 | 11:57 AM
DejaVu85's Avatar
śïιέит вµт đέαđιý
6speed?
sorry, its a AT
Old Jun 3, 2019 | 12:08 PM
DejaVu85's Avatar
śïιέит вµт đέαđιý
Could it be maybe be something in the ignition part itself or is there some sort of relay?
Old Jun 3, 2019 | 12:18 PM
Where did you get the new starter?
Old Jun 3, 2019 | 12:40 PM
DejaVu85's Avatar
śïιέит вµт đέαđιý
Got it from Rock Auto.
got the Power Select Brand
Old Jun 3, 2019 | 04:03 PM
Turbonut's Avatar
When you find out, let me know as over the last year it's happened maybe 3 times.
Turn key, buzzing, release, try again and it fires right up.
I guess it it gets bad like yours I'll need to do some searching.
Usually if the starter/solenoid bad they'll be some noise at the starter while this sounds close, maybe even in the cabin
when trying to start, but it happens without any warning so difficult to pinpoint.
Here's something for you and me, Ignition starter switch:
Old Jun 4, 2019 | 06:58 AM
DejaVu85's Avatar
śïιέит вµт đέαđιý
I found a video on YouTube with the exact issue.
The guy replaced the ignition switch on the bottom left of the steering wheel.
Looks like it’s a $30-50 part in Canada.
Old Jun 6, 2019 | 07:51 PM
AgentSteel454's Avatar
I had a similar issue with my 06 for a while It would start acting the same way. I cleaned and wire wheeled all of my ground points and cleaned the wires up real good and never had an issue after that.
Old Jun 8, 2019 | 12:16 PM
WDPanda's Avatar
I would take a multimeter to see if there is 12V at the starter SIGNAL wire (the small wire next to the constant 12V POWER). Takes a few seconds and eliminates the guesswork.
Old Aug 12, 2020 | 10:55 AM
DejaVu85's Avatar
śïιέит вµт đέαđιý
https://youtu.be/-ihu_wBYNd4
btw this worked!
Old Aug 13, 2020 | 07:08 AM
DMZ's Avatar
DMZ
Head a da Family
Don't forget to replace the + battery cable. At this age, it's more than likely corroded internally where you can't see.
Megatron
Sep 19, 2024 05:50 PM
Ryley
Feb 27, 2016 03:47 PM
Tylervuu
Aug 11, 2015 08:43 AM
rnvander
Feb 18, 2011 07:35 PM
