99TL - ignition switch related to ignition coil failure?
Old Feb 18, 2011 | 08:18 AM
rnvander's Avatar
7th Gear
Unhappy 99TL - ignition switch related to ignition coil failure?
Past few months I have had random stalling while driving under all conditions. Turned out to be the Ignition switch. It was replaced under the recall back in 2004, so this one I had to pay for. This was done last week.
Yesterday I was driving to work and the car started to rough idle while waiting for the light to change. The "rough grinding" noise continued even revving the engine in park. Pulled off into a parking lot, and noticed a pretty bad smell coming from the exhaust. Had it towed in to the dealership (auto club = free) and they said the ignition coil had failed. They also recommended replacing the spark plugs.
I am not a car guy, but could the new ignition switch have caused the ignition coil to fail? If so, is there any recourse I should have with the dealer or is this just a downstream impact when I first replaced the ignition switch? Will wait to do the spark plugs until next month, as these recent ignition issues have already depleted my car budget for February!
Thanks for the input.
Old Feb 18, 2011 | 08:42 AM
rcb2000's Avatar
not related at all replace the bad coil and install new plugs
Old Feb 18, 2011 | 10:51 AM
01tl4tl's Avatar
how many Kms on the plugs?
Old Feb 18, 2011 | 02:14 PM
fsttyms1's Avatar
Not related.
Old Feb 18, 2011 | 06:45 PM
rnvander's Avatar
7th Gear
Thanks for all your input. Just checked my records. I have never actually replaced the spark plugs, so there is probably over 140,000 kms on the current ones. Noticed the Acura techs recommended replacing the plugs back in 2006... Hmmm, maybe it's time?
Old Feb 18, 2011 | 07:35 PM
01tl4tl's Avatar
about 5 years ago!!!
you are about 100kmiles on them- the most acura even says to run them
ngk Iridiums are in your near fuuture~
MrHeeltoe
20
Feb 23, 2023 01:54 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
malvothegreat
Sep 29, 2015 12:38 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
