2000 tl 4dr trunk latch not working.
Old Feb 13, 2011 | 01:29 PM
reloader's Avatar
Looking for assistance with trunk latch not working. no noise when activating door release button. trunk lid latch looks ok but will not lock when manually rotated into place. spring in latch is in tacked. can't find any fuse labeled as trunk & all other accessories seem to be working. checked fuses on each side of dash @ door opening & main fuse box under hood. vfy'd switch @ glove box is not deactivated. remote fob will lock & unlock doors but trunk release not operable. Any one have suggestions where to go from here?? thanks
Old Feb 18, 2011 | 08:47 PM
falconsman's Avatar
when my trunk would not close, yet all appeared to be fine, I had to purchase a new trunk latch from the dealer, cost around 125.00, pretty easy to install yourself even with minimal knowledge, dont know if this helps.
Old Feb 19, 2011 | 05:20 PM
sypher2020's Avatar
7th Gear
I had the same issue for a couple of days on '02 TL. Tune the radio to no channel/static and press the door button to release the trunk. You should hear a little "pop" in the speakers which is the load from the trunk lock. This proves the switch is okay. After that, dismantle the lock/ actuator and ensure everything moves freely, lubricate and check the operation. That's all I did to mine and it has been fine for over a year now. It's worth a try.
baelim
May 10, 2018 09:53 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
spoiler900
Sep 23, 2015 04:41 PM
rboller
Sep 23, 2015 02:49 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
