Help!!!
Old Aug 22, 2019 | 10:01 AM
  #41
horseshoez's Avatar
Latent car nut
Originally Posted by typeS219
I know i see the aftermarket clutch and flywheels out there but ive herd bad stories about them too. I just want to be safe cause i def dont want to have the tranny pulled out twice....as for the case, it is definitely not cracked, however leaking from the seam because the asshole from acura who did the recall didnt do it well....my clutch is in good condition, meaning it still grabs and doesn’t slip but i figured since its out, mind as well put a new one in to make this thing run to 200k
I kind of think you are missing the "aftermarket" point; the OEM maker of our 3G TL clutches is LuK; the exact same Dual Mass flywheel your local Acura dealer will sell you is available from RockAuto for $163. The pressure plate, clutch disc and associated parts, also from LuK via RockAuto is available for $173.
Old Aug 22, 2019 | 02:32 PM
  #42
typeS219's Avatar
Thank you I appreciate your help with that....however for the motor and tranny mounts you said just go oem right?
Old Aug 22, 2019 | 03:51 PM
  #43
horseshoez's Avatar
Latent car nut
Yes, especially for cars with manual transmissions. The only exception that would be if you want to race your car, then solid mounts might be more appropriate, but they will impart a certain amount of vibration to the car.
Old Aug 22, 2019 | 04:45 PM
  #44
typeS219's Avatar
Got it..thanks man
fabrizzio71
1G CL Problems & Fixes
Dec 16, 2012 04:50 PM
ThreePointTwoTeeEl
Jan 24, 2012 11:39 PM
acurakar
Apr 24, 2007 10:00 PM
xxnonamexx
Mar 15, 2007 07:46 PM
RooEng
2G CL Transmission Recall Q & A
43
Sep 8, 2004 10:29 PM
